Old 05-30-2012, 08:42 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
power steering pump
As I was coming home from work, my power steering was getting harder to turn. I opened the hood and found fluid all around the resevior. I opened it and it still has fluid in it. I started the car and the pump made this noisy grinding sound. The pulley is turning and the fluid rises. The hoses are fine, I replaced them a few years ago and I also replaced the o-ring at that time.
Do I need a new pump? Should I try something first before replacing it?
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 05-31-2012, 03:14 PM
dannmarr's Avatar
I work for my SVX
Re: power steering pump
Thanks for all the replies
I found the problem. I can not believe the two bolts that hold down the resevoir was completly loose. The fluid was draining from below. I recently had my rack replaced, could the mechanic have done this and maybe forgot to tighten it? I'm sure he will not admit this. Should I use lock tight or add rubber washers under the bolts?
Subaru SVX for fun
Old 05-31-2012, 03:34 PM
immortal_suby's Avatar
Thread Killah
Might want to check to be sure the O ring wasn't damaged. They do become brittle. If it had already hardened and then lost it's home it may leak after the re-tightening. I've never used locktite on them and have not had one come loose. Maybe he only finger tightened it and then forgot to hit it again with a tool to secure it.
Locker Link
2015 BRZ Limited 6MT
Old 06-01-2012, 11:48 AM
dannmarr's Avatar
I work for my SVX
After replacing the o-ring and retightening the bolts, the noise is still there. It sounds like the bearings. The bolts might have loosened with the vibration.
Time to rebuilt the pump. A project was overdue
Subaru SVX for fun
Old 06-12-2012, 09:02 PM
dannmarr's Avatar
I work for my SVX
I finished rebuilding the pump and installed it. I also replaced the belt. All works fine. I called my mechanic to tell him what I did. He said it was a good idea to change the belt because it was squeeling when he replaced my steering rack. He said he tightned the belt real tight to stop the squeeling.
This is probably the reason for the bearing failure!
Subaru SVX for fun
Old 06-12-2012, 10:41 PM
Good to hear you found the problem and it is fixed.
