Hub removal
I usually bring the housing assembly to Subaru to press out the Hub and bearings. This time I would like to do it myself. How do you press out the hub from the housing without crushing the back plate. Is there a special way to set it up on the press without damaging the other parts?
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
Re: Hub removal
While installed I use a slidehammer.
Re: Hub removal
I don't have a slide hammer Has anyone used the press bench rather than a slide hammer? If so, how did you set it up?
Re: Hub removal
I brought the housing assembly to my mechanic. He was able to remove the hub without the press. I was very impressed by his method. It is hard to explain, so I'll take some picture with instructions the next chance I get.
Re: Hub removal
This is how my mechanic removed the rear hub from the housing. He took off the bolts that hold the back plate to the housing. This enabled him to slide the back plate far enough to grab the housing from the inner side with clamp. He set it up on a bench vise. He then slowly cranked the jaw clamp until the hub was pressed out. He did the same with the bearing.
Re: Hub removal
they make a really neat tool called a hub tamer. I never used one til I started working at last shop I was at. Its like a mini press/slide hammer deal where u can do wheelbearings/hubs on the car
You may be able to rent one from a tool shop (they are pretty spendy to buy if you are just a backyard mechanic it takes about 10 bearing/hub jobs to equalize the cost)
92 Svx 4.44 swap 198k miles. Toyo Garit KX tires.. my Icetrack car 86 Lifted GL wagon well over 600k miles on the chassis 98 Outback 5 speed 6 inch lift, forester struts/springs 29" tires |
Re: Hub removal
When YT changed the bearings at my house, he used a hub tamer. Bearings are holding up nicely...Factory bearings, did not repack them.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
