inoperative turn signals
Yesterday and today, the first time I attempted to signal a turn, the signal did not work. Checked the other direction and got the same result: no blink, no nothing. Curiously, both days, at the very next turn and for the duration of the trip, the signal worked. Hazard flashers appear to function normally.
Seems reasonable to assume the switch is failing. Any other explanation? Does anyone know if the entire multi-switch assembly must be replaced, or are there "user-serviceable" parts inside? Thanks, dcb |
Re: inoperative turn signals
Do you have reverse/backing up light? If not, check the fuse under driver dash.
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD 92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD 92 Teal SVX LSL lowered with Konig. SOLD 92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone 94 Red SVX L FWDwith LSL Leather Interior. SOLD 92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD 95 Polo Green........With Trany Problem. GONE Almost complete Rear Wheel Bearings Job with Pictures in my locker My Locker http://www.subaru-svx.net/photos/user.php?pearlm30 |
Check the bulbs. My turn signal lights go out when the truck slams and the bulbs get loose or break.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
I don't believe I'd be experiencing intermittent operation if it were a blown anything.
dcb |
Keith |
Start by turning all your lights on and walking around the car. If only the headlights work and everything else is out then it's the fuse under the dash. If everything work fine then move on to replacing the flasher relay.
My heart sank a bit when the hazards worked, and my worst-case brain immediately concluded: It's the switch. I'd definitely replace the flasher before resorting to drastic measures. Now, where under the dash is the thing? dcb |
Keith |
Also, I had it in mind that when a flasher relay fails, the indicator illuminates, it just doesn't blink.
Worked fine today when I ran out for lunch. Thanks, dcb |
Which means... the flashing unit has electrical power to it. Which means that the flashing unit is defective, if we discount the possibility that the combination switch is defective. I personally would discount that possibility, considering the current flow level in the circuit. Good luck! Keith Last edited by kwren; 05-07-2012 at 12:45 PM. |
The Flasher is mounted either underneath the column, or right next to the column, as I broke one in my first 5-speed swap when I dropped the column....
Picked up a new flasher today (<$12.00 @ O'Reilly Auto Parts). Of course, since my first post, the thing has worked perfectly. She's messin' with me again.
Will report back if the problem persists. Thanks again to all. dcb |
It takes an electronic flasher, not the same as all the other Subarus of that era, so they might have sold you the wrong one....so let us know if it works.
They gave me a rectangular unit of the sort that comes to mind when one thinks of a relay; not the cylindrical gizmo I recall replacing in some car years ago. We'll see.
dcb |
The electrical leads on this car are reversed compared to most other cars if you plug it in and nothing works it is most likely the wrong one. I had this trouble on mine when I switched to a led friendly flasher I couldnt get the correct one so I just rewired the plug.
