Old 03-27-2012, 12:16 PM
TheRealStig TheRealStig is offline
A/C condense water outlet clogged?
After using the A/C and switching to ECON it gets damp inside. How will I know, if the condense water outlet is clogged?
Old 03-27-2012, 12:26 PM
Re: A/C condense water outlet clogged?
most likely the evaporator case drain is clogged. the evaporator is the part that is inside the car. if you look outside the car on the opposite side of the firewall from where the evaporator is you should see a small tube coming out where the water would normally drain.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1956 Plymouth Belvedere - Daisy
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 03-28-2012, 06:21 AM
I guess, blowing air through the tube might cure the problem.
Old 03-28-2012, 08:07 AM
you might want to poke something in there to clean it out such as a pipe cleaner or heavy guitar string. if you blow air into it then all the debris will be pushed inside and eventually end up back where it was.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 03-28-2012, 11:01 AM
kwren's Avatar
kwren kwren is offline
I would probably suck it out with a wet-dry shop vac and get the mess out of the thing!
Keith
