Old 03-23-2012, 02:24 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
Quick Question
Will changing my "oil pressure sending unit" help stabilize my idle?
cus it only has issues in warm weather...when its below zero it runs like a champ but in warm weather when the oil is thin it runs like crap at idle at speed its fine.
Jared
1992 dark teal SVX LS
Old 03-23-2012, 02:40 PM
Re: Quick Question
probably not. coolant temp sensor would be more likely to help.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 03-23-2012, 03:51 PM
Re: Quick Question
Agreed. 123
Old 03-23-2012, 04:26 PM
Re: Quick Question
Is that as easy as the later or do I have to take it in?
Jared
Old 03-23-2012, 04:47 PM
Re: Quick Question
it's easy. it's on the coolant crossover pipe that runs under the intake manifold. look at the driver side where it is no longer under the manifold. there are two, one for the gauge and one for ecu. don't remember which is which but they are cheap enough to replace both, or wait for someone with a better memory to chime in.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 03-23-2012, 04:55 PM
Re: Quick Question
the 2 wire sensor that uses a 19mm deep well to replace is the one to replace.
I've only seen one gauge sensor go bad.
Old 03-23-2012, 04:58 PM
Re: Quick Question
All I remember is that the brown one is the one that goes to the ECU. The gauge one isn't worth changing, IMO. I got one from rock auto that I haven't changed yet.
Old 03-23-2012, 05:05 PM
Re: Quick Question
Are they the same part or 2 different ones? So it sounds like I dont have to take anything off.to get to it....
Jared
Old 03-23-2012, 05:07 PM
Re: Quick Question
different parts and don't have to take anything apart, just have the new one ready to stick in and do it on a cold engine so you don't lose coolant.
Current Stable:
1992 SVX
1967 Chevy C20
1953 Chevy 210
1959 Chevy Apache
1951 Chevy Stepside
Old 03-23-2012, 05:13 PM
Re: Quick Question
Sweetness!
Jared
Old 03-23-2012, 07:52 PM
Re: Quick Question
Make sure that you change it when the engine is cold, and IF it has or NEEDS a copper O-ring.
Old 03-23-2012, 08:10 PM
Re: Quick Question
Yes SVX god *bows to ground*
Jared
