Old 03-15-2012, 01:08 PM
redlightningsvx's Avatar
Collision Refinishing Tech
car stalls out after trans line breaks
Well my girlfriend was driving the pearly home and I noticed a fluid trail. Pulled it into the garage and toticed a hole in the hard line that goes to the rear housing of the trans. Put a new hard line in and the car just starts then a couple seconds later it dies. So I think MAF sensor so I unplugged it and it ran without stalling. I'm guessing the MAF is bad so I take the one out of my gar and put it in hers and it still dies when its plugged in. Note this just happened out of no where. Not getting any codes either. Can it be drivin without the maf plugged in until i find the problem? What could cause this? Thanks
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-15-2012, 01:25 PM
Wikedjuggalo's Avatar
Rebuilding
Re: car stalls out after trans line breaks
Vacuum lines? also check grounds.
Old 03-15-2012, 01:27 PM
Vaccuum lines are good and all grounds are good.
Seth
Past subies:
Other toys:
Old 03-15-2012, 03:13 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Did either O2 sensor get flooded with oil?
Old 03-15-2012, 06:50 PM
Cam sensor is possible. My FL claret would do the same thing and that turned out to be the culprit. Something easy enough to swap from your red.
Old 03-15-2012, 07:11 PM
Well after scratching my head and checking multiple things I found out why it's stalling but it's odd that it just did it out of no where. It was the air filter I said what the hell and removed it and plugged the maf in and to my surprise it started right up and idles real nice. So bought a new filter and all is good.
Seth
Past subies:
Other toys:
