Old 01-31-2012, 09:44 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Changing the alternator tomorrow...
So, when I first loosen the locking nut that secures the tensioner pulley, it says to unbolt it 1 turn at the most. Will it work if I do half a turn? Then when I loosen the tensioner adjustment bolt, are there specific amounts of roations that I need to screw them back to? E.g., should I count how many times I unscrew it, or will it simply stop once it's on?
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 01-31-2012, 09:53 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: Changing the alternator tomorrow...
I've never heard the "one turn" on the locking nut? You'll see that the pulley becomes loose, then stop turning. Before you turn out the long tensioner bolt. Get some penetrating oil on the upper threads. A few inches of the bolt has been exposed to the elements for XX,XXX miles and it tends to get resistant to turning as you get up to the gunk.
Also the easiest way to turn out the tensioner is to put your 12mm socket on the bolt. Then use the longest extension you have or multiple shorter extensions and poke them down below/behind the alt pulley. This will position your ratchet above the AC compressor. It's not a straight shot, so either use a wobbly or hold the socket on the bolt and don't fully insert the extension into the socket.
Old 01-31-2012, 11:55 PM
OR a short 12mm ractheting box end.
Old 02-01-2012, 05:15 AM
dcarrb dcarrb is offline
Second that. A set of unremarkable ratcheting box-end wrenches is one of the better tool investments this non-mechanic has ever made.
dcb
Old 02-01-2012, 07:06 AM
dcb
When I started turning wrenches on (Fred Flintstones car as I remember)
these did not exist.
Now they are my most used tool!
Old 02-01-2012, 03:16 PM
kwren's Avatar
kwren kwren is offline
A second "easiest way" would be to lubricate the threads and turn it with an air ratchet with the socket right on the bolt.
Keith
Old 02-01-2012, 05:57 PM
B 4 You's Avatar
#lolsvx
they had tools back then?!
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 02-01-2012, 08:13 PM
Keith
Sure, if you want to snap the tensioner bolt.
Old 02-02-2012, 02:51 AM
My friend Moog and I made them from stuff.
We had more time back then....
sigh.....
Dating was simpler too.
sigh........
