water pump and timing belt change, what else should i get?
i will be fixing my svx (has bad head gasket) and im planning to change the timing belt and water pump since the engine will be in parts. what gasket or parts should i also get besides the water pump and timing belt.
Re: water pump and timing belt change, what else should i get?
Timing belt and idler kit from eBay, the powers that be say nothing less than an OEM water pump though. www.1stsubaruparts.com
I was going to attempt to see if an STi pump would fit ours but my "friend" sold it out from under me after telling me I had first dibs. You can tell I'm not mad about it though =) |
As far as the water pump, I have an A-1 Cardone reman in mine and it is just fine..... but if you have the funds id do OEM, if not then the CSK version was like $36. |
Reman water pumps are a nightmare. I won't put them on a car in my shop, I'd loose the job before I would. I don't want to have to do it over again. Your used OEM is better than a new reman. You get what you pay for. Reman anything is junk unless it comes from the manufacturer. (CVs, starters, w/p, and especially alternators).
2007 GS 450h-Active Stabilizer/Radar cruise 1994 L Blue 3.70 VTD ASE Master Automobile ASE Advanced Level Specialist Toyota Master Diagnostic Technician (former life) |
At our shop, if the customer didnt want to pay for dealer or premium remans, we would recommend they supply their own part, which would void the repair labor warranty on any parts failure. |
Not trying to be contentious; just relating my experience: I've been driving for over 30 years, mostly well-worn cars (including 50,000+ miles in the left seat of an SVX), and I have yet to buy or specify an OEM part when an aftermarket/reman equivalent is available. I did have to replace a reman AC compressor last year, but that was under warranty. Could be I've just been lucky.
That said, it sure would be a drag to install a water pump that turns-out to be junk. I'd include a thermostat and bypass hose in the timing belt/water pump job. dcb |
Replace the complete adjuster assembly, if you abide by advice from way down under. This often seizes over time, due to lack of movement and is a prime cause of attendant damage in all Subarus. If you do not replace it, clean and check it very carefully.
i think im planning to buy the ebay whole kit (water pump and timing belt) did any one work w/ them before?
You get what you pay for. Subaru spent an outrageous amount of money developing the powertrain in this car. Using substandard parts would be foolish. I've been working on japanese cars for 10 years, and I use factory parts. That should tell you something. Don't buy an aftermarket thermostat, that's one of the worst parts to skimp on. There is a major difference between aftermarket and factory on thermostats. And while you're at it, Subaru uses a coolant that has a special formulation. I'd check that out.
cool. i went to www.1stsubaruparts.com since i have an account there but i cant log in, it gives me the error of website not trust, is it just my computer or do you guys have the same problem.
i use firefox lol im going through explorer changing the security setting
thanks... it was on medium high, now is on just medium security and works thanks. i was getting so pissed off |
ok this is a list of parts of what i have:
-Mechanical Catalog - Subaru Head gasket, svx - 3.3l, svx 1992 - 1994 pieces:2 -Mechanical Catalog - Subaru Camshaft seal, svx - 3.3l, svx 1992 - 1994 pieces:2 -Mechanical Catalog - Subaru Valve cover gasket, svx, no. 1, right - 3.3l, svx 1992 - 1994 pieces:1 -Mechanical Catalog - Subaru Valve cover gasket, svx, no. 1, left - 3.3l, svx 1992 - 1994 pieces:1 -Mechanical Catalog - Subaru Valve cover gasket, svx, no. 3, left - 3.3l, svx 1992 - 1994 pieces:1 -Mechanical Catalog - Subaru Valve cover gasket, svx, no. 3, right - 3.3l, svx 1992 - 1994 pieces:1 -OEM Catalog WASH ROCKER CVR pieces:16 -OEM Catalog O-RING pieces:1 -Mechanical Catalog - Subaru Manifold gasket, svx, upper 1992 - 1994 pieces:2 -Mechanical Catalog - Subaru Manifold gasket, svx 1992 - 1994 pieces:2 - and brand new radiator - e3 spark plugs pieces:6 now this are the parts im planning to get and on this days: -1 Subaru timing belt -1 Subaru water pump -1 Subaru water pump gasket -1 oil filter ( i dont know what brand yet, fram probably since i never had problems w/ them) - 7quarter of royal purple any thing else should i get? |
Thread Tools | |
Display Modes | |
