Old 08-21-2009, 10:45 PM
Gamesy's Avatar
Gamesy Gamesy is offline
wheel holes not aligned
I was changing my sparkplugs the other day and i jacked the car to use the hole in the wheel well. the drivers side went off without a hitch but the passenger side holes dont even line up they are WAY off. anyone else have this issue?
Old 08-22-2009, 05:45 AM
Re: wheel holes not aligned
I'm betting you have a broken motor mount on that side...very common...
I usually get the passenger side out from up top, not through the wheel well...
Old 08-22-2009, 08:43 AM
Gamesy's Avatar
no i mean the holes in the body themselves are offset, my mounts are fine and has nothing to do with it, its fkd lol
Old 08-22-2009, 09:30 AM
redlightningsvx's Avatar
Collision Refinishing Tech
There supposed to be that way. You can remove the pass. side spark plugs in the engine bay.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 08-22-2009, 10:02 AM
But if the engine mounts or mount is broken, the plugs may not be able to be gotten to as in this case.
Old 09-01-2009, 10:03 PM
Gamesy's Avatar
engine mounts will only offset the engine but it wouldnt offset the holes in the fender
Old 09-01-2009, 10:15 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
The passenger holes arent supposed to line up, and arent for accessing the passenger side plugs. Removing the airbox and bracket will allow easy access to the coils on that side.
Display Modes
