Old 01-10-2009, 11:00 PM
Frogman75 Frogman75 is offline
Question dashboard vent question...blow job??
New to site,,,,have always wondered if dashboard vents are supposed to blow hot air if put on heat with econ or auto setting...mine never have, just allow air flow on vent or ac.........is this how it was designed or does my wife have a valid complaint over the fact that she can't dry her fingernail polish in my svx??
Old 01-10-2009, 11:11 PM
Green1995SVX's Avatar
Re: dashboard vent question...blow job??
Yes. That's just the way it is. Subaru explains it as a feature as it will not dry out your eyes.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 01-10-2009, 11:22 PM
Cool Re: dashboard vent question...blow job??
seems strange, but true......thanks......here's another that may stump you...now and then my abs pump does not shut off when car turnned off and this runs down the battery to zero.......intermittant, but annoying...any ideas on how to prevent this??
Old 01-10-2009, 11:37 PM
It's a faulty ABS relay. It's a common problem on all 90's Subarus. If you open your hood, locate the abs pump on the passenger side front of the engine bay. You'll see a cover that has "ABS" printed on it in big letters. It's secured by a single Phillips screw. Remove the screw and the cover.
It can be replaced with a standard Bosch style relay which you can pick up at Radio Shack. 30 amp automotive relay part number 275-226 ($6.79).
http://www.radioshack.com/product/in...ductId=2062477
In the meantime, you can give the top of the box a brisk tap with your hand. This will stop it from running.
If you'd like to go with a genuine Subaru part, the part number is 26735AA012 from the subaru dealer. It retails for $51.45.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 01-11-2009, 12:09 AM
Smile Re: dashboard vent question...blow job??
I am impressed.........and humbled by your knowledge of all things svx...thanks for the info and happy svxing - I mounted my snows today and am looking forward to flexing my svxness in the morning on my way to Radio Shack!!
