Old 12-22-2008, 05:56 PM
IceBlade's Avatar
IceBlade IceBlade is offline
Send a message via MSN to IceBlade
PCV Valve
Sometimes on start up I get a cloud of smoke from my exhaust. Someone told me I should probably change the PCV valve.
Anyone know the part number and a good place to get one?
Old 12-22-2008, 06:22 PM
svxpert svxpert is offline
Re: PCV Valve
<<Sometimes on start up I get a cloud of smoke from my exhaust. Someone told me I should probably change the PCV valve.>>
what color smoke?
Old 12-23-2008, 07:01 AM
ssnsltd's Avatar
ssnsltd ssnsltd is offline
That's gona leave a mark.
Re: PCV Valve
if it goes away after a few minutes, it is likely condensation in the pipes.
white= is generally coolant, has kind of a sweat smell to it.
blue(ish)= oil, smells like burning oil. if it goes away after a few minutes, likely valve seals. if it gets worse when you hit the throttle it is likely rings.
black, when you hit the throttle= rich
David
96LSi 102k Laguna Blue
95 LS-L AWD, Safety package, 140k Polo Green
the Chick Magnet:
91 Justy GL EFI 4x4 154k (new motor @120k)
90 Yamaha V-Max
82 Yamaha XJ650LJ Turbo
My Diver Propulsion vehicle:
88 Jeep Cherokee 160k
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
85 XT AWD/4x4 Turbo Space Blue
Old 12-23-2008, 07:47 AM
IceBlade's Avatar
Re: PCV Valve
Well it hasn't done it is awhile and I don't remember what colour it was. If I had to say a colour I'd say blue but I can't be sure.
Old 12-23-2008, 08:10 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: PCV Valve
Mine does the same thing.. Although I can't tell if mine is white or blue.. Either way it's there ALL the time. How do you fix both?
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 12-23-2008, 08:33 AM
ssnsltd's Avatar
Re: PCV Valve
if it isn't a thick cloud/has no oder, it is pretty much normal, for winter especialy
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-23-2008, 08:39 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: PCV Valve
The blue cloud could just be an oil overfill, too. I've had the pros do that to me once.
Old 12-23-2008, 09:21 AM
Re: PCV Valve
Define pros.
Old 12-23-2008, 09:23 AM
IceBlade's Avatar
Re: PCV Valve
Ah. Maybe. I just put in a lot of oil.
Old 12-23-2008, 09:31 AM
LetItSnow's Avatar
Re: PCV Valve
Define pros.
Uh, a guy who gets a paycheck, regardless of training, knowledge or skill?
I look at it this way: at least I wasn't shorted oil!
I'm not implying that you can't read the stick; moreover, it shouldn't be overlooked that the doom posted above (valve seals, shot rings, etc.) isn't the only reason you'll see blue smoke. Somebody else on the forum had an overfill, as well. It happens!
Old 12-23-2008, 04:59 PM
ssnsltd's Avatar
Re: PCV Valve
if he has too much oil, it will smoke until the oil is gone. not just on start up.
next time you start the car, have someone else do it and look at the color, how long it smokes, and how intense is the cloud (ie, just a little or are you fogging for mosquitoes)
David
the Chick Magnet:
90 Yamaha V-Max
"U-sta-have"
88 XT6 AWD Pearl,
86 XT Lt Blue,
Old 12-24-2008, 02:13 AM
kwren's Avatar
kwren kwren is offline
Re: PCV Valve
go to this link, print it out, and hold it up while someone else starts the car and find the correct color for the smoke!
http://images.google.com/images?ie=U...num=4&ct=title
Good luck,
Keith
Old 12-29-2008, 12:25 AM
Hondasucks's Avatar
Subaru Technician
Re: PCV Valve
I got a free subaru once that smoked all the time.. Part of it was the cracked head, but it also dumped blue smoke, and I replaced the PCV valve and the blue smoke went away. Still dumped huge clouds of white smoke though :P (Drove it back from Hood River with the temp. gauge one bar away from the red )
1986 VW Jetta
