replacing water tempgauge
I've been thinking about this for a while and was wondering if I removed the stock temp from the gauge cluster could I use the leads from that to put in something like this in its place? http://store.summitracing.com/partde...5&autoview=sku I ask because since the stock is all electrical do I need to but a sending unit also or can I just use the stock one?
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
Re: replacing water tempgauge
While you're at it...
I'd been thinking that the two little status thingies (top left and right on the panel) are basically useless and would serve much better as functional gauges (trans temp and voltage maybe). Do you know if there's anything behind the panel there that would strongly object to having a hole cut in it?
Last time I had mine out there were just sockets for lights. I too was thinking of adding another gauge there if I can fit the water gauge in there, but I might have to cut some of the plastic shield also unless I can dremel enough from the cluster.
there was a post a few years ago on this, the guy replaced both lower gauges with aftermarkets, can't remember if he put in gauges where the lights are, and I couldn't find the post on a search.
the gauges he put in did not require a mod to the housing. thought he used stock sensors. anyone have a link to that thread ??
David 96LSi 102k Laguna Blue 95 LS-L AWD, Safety package, 140k Polo Green the Chick Magnet: 91 Justy GL EFI 4x4 154k (new motor @120k) 90 Yamaha V-Max 82 Yamaha XJ650LJ Turbo My Diver Propulsion vehicle: 88 Jeep Cherokee 160k "U-sta-have" 88 XT6 AWD Pearl, 86 XT Lt Blue, 85 XT AWD/4x4 Turbo Space Blue |
The dash coolant sender is the single pin sensor on the crossover. It can be removed and replaced with a new sender for the digital gauge with no ill effects on the car's performance or ability to monitor the temp. BUT you cannot remove the two pin sensor next to it.
Tom |
Tom got any pics of the sensors so I have a visual idea?
I don't, take a look at the back driver's side of the engine. Under the manifold in the back corner you will see a single spade connector plugged into a small sensor and then a brown/red connector w/ two wires plugged into the other sensor. They are right next to eachother on the corner of the coolant X-over pipe
Tom |
Thanks, i'll check it out soon.
http://www.subaru-svx.net/forum/showthread.php?t
3 posts down you'll find a pic of my trans temp gauge, I had no problems hacking up the cluster. |
The more recent gauges that were placed in a cluster were VERY small, and mechanical (and not mine, for clarity):
I'd find it hard to believe that any gauge replacement wouldn't require at least some modification to the cluster. I placed a pair of ISSPROs in my cluster (currently out, being converted to RED ) both on the left side, and I cut an immense amount of plastic out of it to get them to fit, not to mention doing some substantial altering and removal of parts of the circuit sheet behind it. Is gonna look like this:
Disclaimer: The above post is on the internet. Last edited by LetItSnow; 12-28-2008 at 08:27 AM. |
Thanks for the pics. This gives me an idea so far on what needs to be done. Are those gauges 2 1/16, and what is the hieght on them? I ordered a tranny temp gauge first and got a extra cluster coming so i'll post how it goes. I want to get at least the tranny gauge put above the coolant temp for now then if it all fits nice then i'm getting the coolant gauge.
Thread Tools | |
Display Modes | |
