Old 06-04-2002, 09:39 PM
billisa
Moonroof sticks
My moonroof won't always lift up unless I give it a nudge. Is there something I should use around the rubber/felt surround to keep it from sticking? Thanks.
Old 06-04-2002, 10:15 PM
subymtnguy's Avatar
subymtnguy subymtnguy is offline
"high" in Colorado
moonroof...
Mine will occasionally stick after a wash job....
I greased the tracks it slides on with with wheel bearing grease, and it very rarely hangs up....
92 Liquid Silver LSL
85 BRAT GL
81 280ZX
91 Legacy wagon
86 Pontiac Parisenne (55k)
86 Kawasaki ZG 1000 Concours
81 KZ 1000 LTD (shaft)
Old 06-04-2002, 11:01 PM
Aredubjay's Avatar
Rat Fink Member ~:o)
There is a TSB that says to place silicone on the sunroof gasket (not the fuzzy part, just the rubber seal). Some people have also had luck with adjusting the clutch nut, but you can only adjust it slightly. Pull the plastic plug in the roof, behind the dome lights to access it.
Randy Johnson
Mike Davis -- at Reading VI
Old 06-05-2002, 05:08 AM
Phil Hill Phil Hill is offline
Moonroof ??
Must be another language thing, but in UK we call them a "sunroof", which is not strictly accurate when you think how cloudy it is over here all the time With appologies for the spelling and grammer, in france they call it a "finetre anglaise" or English window, so make of that what you will. Anyway, hope you get it sorted soon.
Phil.
Only the depth varies..............
Old 06-05-2002, 06:07 AM
MoreIBNR MoreIBNR is offline
Original Owner 1992-2008
Send a message via AIM to MoreIBNR
Re: Moonroof ??
I am not certain if there is universal agreement, but I think of what we have as a sunroof. The Moonroof is one with glass so you can look out at the sky even when it is closed.
Phil.
Old 06-05-2002, 08:51 AM
Aredubjay's Avatar
Re: Re: Moonroof ??
I'll have to check my "official Subaru Literature" and see what they call it. I believe, however, in the literature, it's called a "moonroof." Perhaps we should call it a "sunmoonnon-t-top-typeroof"
Randy Johnson
Old 06-05-2002, 09:03 AM
subymtnguy's Avatar
"high" in Colorado
Wink moonroof (not!)
The official Subaru sales brochure, 92 SVX......page 17....
"the large electric sunroof....."
I agree with IBNR.....
85 BRAT GL
81 280ZX
91 Legacy wagon
Old 06-05-2002, 09:07 AM
Aredubjay's Avatar
Re: moonroof (not!)
Ah, very cool. Saved me the trouble of trying to find the literature that my wife keeps calling "Randy's junk" and poking it away in some cubby-hole."
Randy Johnson
Old 06-05-2002, 09:12 AM
Aredubjay's Avatar
Yep, sun roof, definitely sun roof. Ten minutes to Wapner. Yeah, yeah. I buy my underwear at K-Mart. I'm a very good driver.
http://members.tripod.com/quick_svx/.../42748041.html
Randy Johnson
Old 06-05-2002, 10:22 AM
kuoh kuoh is offline
It's a motorized semi-permanent overhead moisture barrier. It's not to let the sun in, but to keep the rain out!
KuoH
Old 06-05-2002, 10:42 AM
LarryIII LarryIII is offline
Please note a "Sunroof" and a "Moonroof are 2 different things.
A "Sunroof" is a metal roof piece that pops up and slides back on the outside of the roof.
A "Moonroof" is a clear glass/plastic roof panel that slides back inside the car. It slides between the metal roof and the headliner.
There is an opaque than that slides under the bottom of the moonroof to give privacy when the moonroof is closed.
Larry III
Old 06-05-2002, 11:53 AM
Ok, so what do we call the kind with glass, but slides out over the roof? A "smoonroof"?
KuoH
Old 06-05-2002, 02:25 PM
Kuoh,
It's called a sunroof. There are variations on all of them.
Larry III
It's a smurfroof if the glass is blue tinted.
It's a barneyroof if the glass is tinted purple.
It's a porthole roof if the glass is round.
You may not be able to see thru me but I can still be a pane.
