Old 10-17-2006, 12:21 PM
svxthc's Avatar
svxthc svxthc is offline
How to use Wiring Harness?
Guys, the harness svxdc sent me does not want to totally snap in two the one coming out of the svx, it goes on a little but not all the way... Also do I have to solder the wires coming out of his adapter to my new radio or what? lol Desperate- thanks
1993 SVX Anniversary Edition #64
Old 10-17-2006, 12:44 PM
Speedklix's Avatar
Locker Link Solution
i've never seen this harness, but you ussually splice the wires coming out of it to the wires on the harness that came with your radio. so when you are done one end plugs into the radio, and one end into the SVX harness. It may not be pluging in due to a bent pin. Or maybe it is just a bad item not to insult svxdc or anything cause I really have not even seen one.
Splice and tape/use butt connectors... whatever you want to them. The wires should be labeled or come with a key to tell you what each wire is for. just match the description up with what ever the wires are labeled on the harness that came with your radio. When ever you see "memory" that is ussually the 12v the is always hot... the "power" is the one that is "switched" or "ignition" if that helps with any confusion there too. I am assuming this is your first install is all.
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-17-2006, 12:45 PM
Earthworm's Avatar
Meow!
Make sure all the pins are lined up.
You should solder & tape all the connections to the harness that comes with the radio.
Old 10-17-2006, 01:03 PM
svxthc's Avatar
Guys, this radio is so tight that it morphs the cage and the holes do not line up- I'm thinking I wont even screw it in it is so tight. What do you guys think? How do I insulate the top din?
Old 10-17-2006, 01:17 PM
svxthc's Avatar
Nevermind, the button wasn't pushed in. My new deck has new wires coming out of it and only one antenna wire, where do I plug these new wires? Alpine 9856
Old 10-17-2006, 02:06 PM
Speedklix's Avatar
subaru actually has a few pieces that could go there to fill the din. I can't remember where to get one, but there is a plastic piece that that says subaru on it that will screw into the cage. in any of the big audio sites you should be able to find other "blanks" and cd organizers that could fill the spot. I originally cut a piece of aluminum and mounted it in the spot, but that requires some fabing ability.
I don't have any idea what button/tightness you are refering too (cage cover maybe), but I guess it is no longer a problem. I would love to go into splicing techniques, but I am off for a "photo shoot". If you must do it now... Simply cross the wires to be joined to form an X. be sure the copper wires touch just beyond the insulation with both pointing up. Twist the two ends over eachother and keep twisting until you run out. This is a basic splice. If you have done it correctly the wires shouldn't form an angle, they should be nearly seemless with the exception of the bump of exposed twisted copper and shouldn't "unwind" with a light tug, cover with electrical tape. It can be explained better, and there are other splices... but i'm in a rush.
-Mike
[SIGPIC][/SIGPIC]
Old 10-17-2006, 02:24 PM
svxthc's Avatar
I appreciate the feedback you guys. NOw MY CAR WILL NOT START. Must the Stereo be plugged in in order for the car to start? This is weird. It fires up for a half a second and then shuts off. HOw could the battery be dead after all of this?
Old 10-17-2006, 02:51 PM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
chances are you had the door open for a couple hours... while you were working on this? with your feet hanging out... (dome light on) chances are you may have had your headlights on the whole time... that is if your key was in the ignition while you were working, and the negative battery cable wasnt un-done...
-drew
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 10-17-2006, 02:59 PM
Earthworm's Avatar
Meow!
I don't think the battery is dead because it wouldn't turn over if it was. Did you unplug anything else under the hood like the MAF?
Old 10-17-2006, 03:49 PM
svxthc's Avatar
Nevermind that, I got it started. I guess when the power antenna and stereo isnt plugged in it wont start. There are white tubes with steel braiding on the inside and holes on the other end. This make the wire virtually useless to crimping. These are on the end of my alpine wire harness, how do I mesh these power ones with my harness? They are illumination- power antenna so fourth.
Old 10-17-2006, 03:53 PM
Earthworm's Avatar
Meow!
Pictures might help
Old 10-17-2006, 06:06 PM
Maybe keep trying until they smoke or spark!
Old 10-17-2006, 07:22 PM
svxthc's Avatar
OMG AFTER 7 HOURS GOD SAID LET THERE BE LIGHT. Alpine is the ****. The 9856 blew my 13 year old speakers out the doors- not literally- but concert hall style. Wow, best 200$ I ever spent.
