Old 07-18-2006, 11:35 PM
Wildstar Wildstar is offline
Security Module and Keyless entry module
Where on a 95 SVX would the Security module and the
Keyless entry module be located?
Besides the Security module, what else is necessary to add the
security feature to a car without one?
Thanks
Chuck E.
Old 07-19-2006, 01:38 AM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
Thanks
Chuck E.
Not sure what it would take to add it to a car that didn't already have it, (Probally just a switch swap and adding the module) But if it already has it, it will be between the speakers in the trunk.
Old 07-19-2006, 04:47 AM
dynomatt dynomatt is offline
My 95 has sensors in the door handles.
So in addition to the module, which on a RHD car is behind the rear right panel and armrest for the back seat window winder.
Old 07-19-2006, 06:04 PM
oab_au oab_au is offline
Matt you can also program the door to unlock, by the number of times you move the door handle up and down. Handy if you lock the keys inside.
One Arm Bloke.
Tell it like it is!
Old 07-19-2006, 06:16 PM
Harvey,
tony (aka Desertrunner) mentioned this, but he wasn't sure how it worked.
Do you know how it works? Each time I lock it, then check it's locked, it beeps at me...then each time I lift the handle again, it keeps beeping at me.
Old 07-19-2006, 08:43 PM
What about the keyless entry module?
where is it located? or is it part of the security module?
Thanks
Chuck E.
Old 07-20-2006, 07:16 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
One module does it all.
Edit: You'll need a wireless transmitter key fob too, of course.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
Old 07-20-2006, 07:51 PM
alltrac alltrac is offline
Thanks
Chuck E.
I assume you have a L model SVX?
You need more then just the module and remote.
I have the last OEM factory accessory alarm from Subaru. It works for all dual air bag model SVX's. Besides the obvious alarm module and remotes to make it work you need the relay harness that plugs in under the dash near the steering wheel and the security switch.
Victor
Harvey,
The beeping when you lift the handle is normal, just telling you "to keep your hands off my car"
The process for doing the keyless unlocking, is here in my locker.
http://www.subaru-svx.net/photos/user.php?oab_au|37061
One Arm Bloke.
Tell it like it is!
Old 07-21-2006, 11:23 PM
I would imagine that the same switch contact that turns on the
nightlight around the keyhole acts as the sensor that makes it beep
when you lift the handle.
What is this wiring harness near the steering wheel? what does it connect to?
Thanks
Chuck E.
Old 07-23-2006, 10:33 PM
dmnknightomega6 dmnknightomega6 is offline
hmm ... since we are here... does the svx have a transponder whatnot on the keys?
Old 07-23-2006, 10:35 PM
Budfreak's Avatar
Banned
No transponder. That didn't start getting used in cars too often until the late 90's or so.
