How do I know if it's the right one?
My front differential gave it all up. There are no locally available cases, so I'm having a complete transaxle (used) shipped in - then I'll have a spare tranny I guess.
Anyway, how do I tell if I've got a SVX transaxle vice Legacy or whatever without disassembly? I have read Aredubjay's horror story about a Legacy unit. Any unique numbers or exterior characteristics???? My concern is I get a Legacy unit then things begin to die because the rear diff ratio is different and all that entails. tia |
all can say is get the number of the transmission you are getting used. there should be a number plate on it, then call the dealer and ask them for that number what it came off of, maybe that should do.
white leathers, h.i.d, ecutune S/C stage 4, 14 inch 2piece rotors big brake kit., , msd ignition, c/f dash kit, front spoiler,carbon fiber jdm rearc wing,19 inch rims, nos, , aem fuel regulater, koni-gc package, ported cylinder heads, supercharger cams,solid buck and shims,wrx sti intake valve and exhaust valves,& valve springs, gas analizer,water injection, exhaust temp gauge, idiglo gauges, shift kit, , remote start, all automatic windows,2.5 inch true dual exhaust system with crossover, and 2 borla stainless steal muffler,air filter velocity air stack 3inch to 6 for air filtre, group n mounts, momo steering wheel, dyno will happan soon |
There's no external "tell" except for the part number sticker that may, or may not be on the unit.
Barring that, your first sign would be when the tranny did not bolt up to the SVX flywheel. Other than "counting teeth" those are the only ways I know to tell the difference. Unfortunately, the stickers were lost on the Legacy tranny when they cleaned it for re-build. I can't believe that Subaru uses stickers instead of stamping or a metal, riveted plate, for identification. You can get the part number from the diagram at subaruparts.com BTW, does anyone need a tranny for a 91 Legacy (non-turbo) with less than 10K on the rebuild?
it should have a identification number on a black plate either on the left side, right side or on the top of the bellhousing, is what ive seen. it should be the o.e plate. they dont take those off, because its a refrence number for warranty on the trans unit
more questions
By the unit not bolting up, I'm assuming you mean the torque converter bolt pattern doesn't match between Legacy and SVX.
Given that, when one buys a complete transaxle, does anybody want to venture an opinion if the torque converter should come with it? If it does, I can compare and have an instant confirmation. If it doesn't, then can I count turns of the axle shafts with the rear output shaft and determine ratio? Are there differences in the shaft that using my old converter would disclose? |
Hmm.. If you're able to get the VIN of the car it came out of it should start with JF1CX3.
Re: more questions
I would imagine that a complete transaxle would include the TC. When I bought mine, it came with the TC which I had them rebuild along with the rest of the transmission (which, is giving me fits again). Dunno about your last question.
Thread Tools | |
Display Modes | |
