Old 09-05-2005, 01:51 PM
troth
the alternator r&r how-to is not correct
I'm not an expert on this, but his picture has the socket wrench on the the mount for the tensioner it should be on the tensioner pulley bolt; thats all that needs to be loosened along with the tensioner pulley bolt! I'll submit a picture if everybody agrees with me on this!!
tr
Old 09-05-2005, 03:32 PM
Post your picture and explain. I would like to see what you mean exactly before I will agree with you. Just need some clarification. Thanks.
Old 09-05-2005, 03:49 PM
UberRoo's Avatar
UberRoo UberRoo is offline
SVX Appeal
I'm not sure what FAQ you're referring to.
The, "Wayne's Alternator Replacement" and "Alternator Replacement" PDF files, which are almost identical are the only ones I found.
1. Disconnect battery
2. Remove the plastic shroud over the alternator.
3. Loosen the nut on the left side pulley.
4. Loosen the tension bolt and remove the belt. (Counter clockwise is loosening the tension)
5. Buy and new Alternator belt
6. Disconnect the connection at the top left of the alternator
7. Unplug the tan plug in the back left side of the alternator. (there is a little clip that holds it in place.)
8. Remove both bolts that hold alternator on
9. One on left side and one on the right. (Those are the only 2 holding it in place
10. Grab a hold of the alternator and rotate up and down until it comes loose.
I think I'd put step 5 (buy a new belt) as the first step, and step 6 (disconnect the plug) would be right after removing the plastic shroud over the alternator. I'm not sure why there's a step 8 and 9. They seem to be the same step.
I don't have any idea what the wrench is supposed to be attached to, and the crank pulley is also missing, which could be confusing because it's not neccesary to remove it.
See the attachment.
1994 LSi, Laguna Blue SVX Appeal
1992 LS-L, Ebony Pearl SVX-Rated
UberLocker
Old 09-05-2005, 04:15 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
The attachment you posted is perfect except that you should always disconnect the negative cable. Reset the radio presets and clock, you don't want any chace of a short. The alarm does not lose its programming for at least 24 hours with the battery disconnected.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 09-05-2005, 06:33 PM
troth
ok this was the link that I was going from
http://www.subaru-svx.net/photos/files/How-To/14322.pdf
and it shows a wrench on the pulley mount not the tensioner pulley bolt!!
now my question is where did this come from because it is correct?
http://www.subaru-svx.net/forum/atta...achmentid=5995
thanks
tr
Old 09-05-2005, 07:31 PM
UberRoo's Avatar
SVX Appeal
Yeah, yeah, I know, I know. Safety first and all that. There's a fusable link in the charging cable. I had the stereo cranked when I was working and I didn't finish putting the alternator back together for several days. I'm a repeat offender, but I'm very proficient at getting away with it. In the worst case scenario, wrenches are replaceable and burns heal. Anybody who steps near the ignition switch while I'm working gets a swift and severe beating - which is actually kind of a perk the way I see it.
UberLocker
Old 09-06-2005, 05:15 AM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
Geniouses think alike, eh? (minus my spelling)
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 11-20-2005, 11:45 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Troth,
I just replaced my alternator and the directions on the "how to" is correct. But as you have mentioned, the wrench in the picture is on the wrong bolt. I believe it just happened to be there when the picture was taken. If you notice the arrows, they do point to the right bolts that need to be loosened. Hope this helps clear up any misunderstanding.
Old 11-20-2005, 01:26 PM
I think this picture was taken for something else and was used for this too.
Old 01-15-2006, 01:45 AM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
this is sort of old, but whats the purpose of loosening the locking nut on the tensioner pulley first anyways?
What happens if you dont do that in the process ?
I recently replaced my PS belt, and didnt loosen that
nut at all
BUT, less then 50 miles later that nut and pulley came loose and popped off.
Coincidense or something I did ?
yeah, I know I should know this but I dont
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 01-15-2006, 07:22 AM
dannmarr's Avatar
I work for my SVX
You need to loosen the pulley bolt before you use the tension bolt because this allows the pulley to ride easily on the guide. In other words, the tension bolt allows you to adjust the belt until the pulley bolt is tightened to set that position in place. (or vise-a-versa). Hope this is clear for you.
Old 01-15-2006, 10:14 AM
nut at all
If you were able to do it without loosening the locking nut, it was too loose and that is why it came loose. It should be tight enough that you could not do the job with out first loosening it.
