Ecutune V1.4 ,code45 is this normal?
Hi, I recently put in my ecutune chip in the ECU box, when I reconected the ground cable and started the car, the check engine lamp lid, then I checked the codes and got a 45.
Resetted the code and then got it back is this right or have I missed something? The car seems to run in better shape though, also conected the shiftkit and it runs great. |
I would pull th echip out and see if it still does it.
If it goes away with the chip removed then verify you have installed it properly and try again. If the code comes back then PM Longassname. I'm sure he'll be able to help. No, it's not normal.
