Old 08-30-2005, 09:51 AM
1992SVX 1992SVX is offline
driver door lock
my driver side lock motor only works sometimes. so i have in and out off the passenger side. i opened the door panel and took at the motor. the acuator that locks and unlocks the door. is in the lock position. i can turn the key and it will unlock but once let go of the key it will lock. i think i a new motor. if so were can i find one
1992 pearl svx (given away)
Custom Cold Air Intake
Stage1 Shift Kit
Brembo Cross-Drilled/ Slotted Rotors. Front and Rear
4.44 gears
now in better hands of svxfiles
Old 08-30-2005, 10:00 AM
Aredubjay's Avatar
Rat Fink Member ~:o)
First of all, let me check the troubleshooting section of the manuals to try and diagnose your problem -- unfortunately, it'll have to wait 'til I get home tonight.
Otherwise, post a message in the "Wanted.For Sale" forum for an actuator. There are several members selling parts right now.
Randy Johnson
Mike Davis -- at Reading VI
Old 08-30-2005, 11:41 AM
Earthworm's Avatar
Meow!
If the motor's locking it's just doing what it's being told. There could be a shorted wire someplace or it could even be the security module.
Old 08-30-2005, 12:34 PM
Aredubjay's Avatar
There's also that mysterious "timer" module (haven't quite figured that thing out yet).
Randy Johnson
Old 09-01-2005, 02:19 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
I can tell you a little about the central locking, assuming it's the same as my Legacy.
The locking is controlled by a single wire that runs from the driver's door lock to the controller. When the wire is earthed, the controller unlocks the door. When the wire is not earthed, the controller locks the door.
When you turn the key to unlock, the lock mechanism moves to the unlock position, this closes a switch which connects an earth to the control wire. Then the controller unlocks both motors. The fact that the lock mechanism is now in the unlock position is supposed to keep the earth applied to the wire so the doors should stay unlocked.
When you turn the key to lock, the mechanism moves to the lock position and releases the earth from the control wire, which causes the controller to lock both motors.
It sounds like in your case, the earth is not remaining applied to the control wire when you remove the key. I would check the microswitches on the lock mechanism and the wires leading to them.
That's how I remember it from when I installed my alarm. I think the principle is right anyway.
Phil.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 09-01-2005, 09:07 AM
Mine does the same thing only if I remove the fuse and replace it everything works normally for a certain time then we are back to getting locked out. Just thought of this what if I REMOVE THE FUSE ALTOGETHER Got to try that at least I can start locking the car untill I fig. it out. Oh dear was I thinking out loud again <LOL>
