Old 04-28-2005, 06:34 PM
My Wife said to me it doesn't work in AUTO she has been driving the car for 10 years I just got hold of it after she purchased her new Acura TL and I sold my 91 turbo 5 speed. I pushed on the button down it went I pulled up on the button and up it came she said Ill be, never worked for me. I guess soemtimes they stick.
Old 04-28-2005, 10:17 PM
Rotorflyr's Avatar
Rotorflyr Rotorflyr is offline
John,
Your wife probably didn't pull all the way up on the button (or push down all the way), as when you lift it "catches" a little before going into the auto-up feature, same on the way down (especialy if it hasn't been used much)
1992 Liquid Silver LS-L (Sold-5/16/13)
1997 Spruce Pearl Outback (Sold)
2006 B9 Tribeca
Old 04-29-2005, 10:44 AM
Blackbir2001
I'm now completely baffled. Both of my JDM 1992 models clearly have 'Auto' marked on the driver's window. Yet neither of them work. In fact, I can't even feel what I would call a second indent to the switch which suggested that it might have worked at some time. You pull the switch up and the window goes up, but there's no suggestion that you can pull it further!
Old 04-29-2005, 11:15 AM
I forgot I had auto up and down because I never use it, and nearly chopped my arm off yesterday
Take your switch apart and look at it. Maybe there's a bad or loose contact.
Old 04-29-2005, 09:57 PM
Rotorflyr's Avatar
In your case it may well be that the switch got used so often that the "detent" portion has worn and you won't fell it catch at all.
2006 B9 Tribeca
Old 04-30-2005, 07:45 AM
immortal_suby's Avatar
Thread Killah
I had an unexpected auto down the other day in mine. Stupid cable broke.
Locker Link
2015 BRZ Limited 6MT
Old 05-01-2005, 03:44 PM
Yoda3000's Avatar
Yoda3000 Yoda3000 is offline
(This account is in rememberance of)Duct Tape Man
Send a message via AIM to Yoda3000
Auto up and down is indeed there, and it's simpler then all of you are making it out to be.
On my 92 I never could get it to work and one day I was poking around with the switch cluster taken apart. Using a screwdriver in the switch'es little slot, I found that auto up AND down do indeed exist, but the switch has a limited range of motion incapable of activating it.
My solution: Increase the range of motion!
I took a file to both sides of the rocker switch and removed large ammounts of plastic. Then it worked like a dream.
Not sure if it's only for 92s or all of them.
Then my car got destroyed and I sold the switches to soobiesvx93 and I have yet to do this mod to my new car. You should PM him and find out if he's still happy with it.
Early deceased SVXWN Member
July 1986 -- February 2007
Michael - Duct Tape Man
1992 Burgundy SVX LS-L, 138K: Brembo Slotted/Drilled Rotors, B&M Tranny Cooler and Filter, SmallCar Shift Kit
1992 Burgundy SVX LS-L, 123K: DEAD FROM FATAL HAIL DAMAGE, Parting out so PM me if you need something.
"It's only after we've lost everything that we're free to do anything" - Fight Club
"This is not my life, this is not my home, this is not me. I HATE THIS!" - Static X
Old 05-01-2005, 07:46 PM
michael's Avatar
michael michael is offline
What Potholes ???
I have a 92 and my switch broke right off. I had auto up and down. I bought a switch from a 94 and no auto up or down. I put the two side by side and the 94 has tabs that limit the range of motion. So naturally I filed off the tabs and still no auto up or down. I ended up using the switches from the 94 and the mechanicals from the 94, now I have auto up & down.
Wanted: Steering Wheel
