Old 03-02-2005, 09:43 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Alarm Transmitter
Just a simple question to make sure.
The car alarm transmitter... It's the same for all years, right? I mean, no one has had to specify the year before buying one, have they?
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 03-02-2005, 10:35 PM
sharky512345 sharky512345 is offline
Send a message via AIM to sharky512345
I believe that there are two different transmitters that were used with the svx. One remote has two buttons and a more common single button transmitter. I am not sure which years came with which ones. But my '96 came with the single button transmitter. Also i am fairly certain that either transmitter would work with your car as long as you programmed it in.
Current: 2005 Black Legacy 2.5i 63k
Previous: 1996 Brilliant Red SVX LSi 117k
Old 03-02-2005, 10:39 PM
There are two types, but the all work the same on all years of the SVX.
Old 03-03-2005, 12:21 AM
Thanks guys. I was just wondering cause I don't have much range. Sometimes, I'm standing right next to the car and have to keep pressing forever before it triggers. And this is with a brand new battery. (I have the battery update, instead of the 8 buttons)
I'm going to design and build an updated version. From what you guys say, the encoder IC is the same for all years. That means they never updated the decoder in the car throughout the SVX's life cycle. I checked earlier and the encoder IC's are still available.
With the exception of the encoder IC, the entire transmitter is discrete components! That is just soooooo 1990. Eats batteries faster than Elvis can down a doughnut and has the range of a burp.
And another thing! The encoder is set up as 8bit trinary (high, low, and float open). That means we should have 3^8 , or 19,683 available codes. But noooooo... All they did on mine, is send one of the pins to ground, and the rest are floating open. I would assume they were just as lazy with the rest. I bet I could go to a meet, and if there are at least 12 SVX's there, I would be able to open one of them. That is, if I stood next to them and pressed the button a zillion times like I have to do with mine.
That's probably why it's so easy to program a new one. The decoder only has to look for 1 lousy transition in the entire 8bit series.
I think I'll make it a standard 3 button and use one of those buttons for the trunk. Set up a solenoid back there with it's own decoder IC, and relay set up. That will keep the wiring stock. I wonder if there are any 12V supplies back there besides the tail lamps? Wonder which manual "that" is in?
How is everybody else's range? Is it just me?
Robert
Old 03-03-2005, 12:28 AM
intellibomb's Avatar
intellibomb intellibomb is offline
phil, if you do decide to go for the trunk opener, you should definitely take pictures and document the process... that would be a cool upgrade.
jj
Old 03-03-2005, 01:19 AM
jj
I will most definitely do that. It's obvious though that it won't work with the original SVX transmitter. The receiver would have to match the transmitter, and building a programmable receiver will price it out of reason for just a trunk switch. At that point, it would become an aftermarket alarm. Besides, everytime you opened the trunk, you would lock/unlock the doors. My mindset is to keep the original alarm and wiring and have the trunk switch a separate entity that's controlled with the same transmitter/separate keypress. I'll have to put up schematics and PCB layouts of the transmitter along with it once I have a good simulation in pSpice. Bring back the days of the old Heathkits.
Hey! That's an idea! Run an order of 100 PCB's once it's designed and then sell kits. The first 2 prototype PCB's are the ones that cost a fortune anyway, after that they are cheap! Finding blank keyfobs is what's bugging me right now, and will probably be the most expensive part of the transmitter.
The university out here has one of those computerized thingys that can make a design out of a solid block of plastic. I don't know AutoCad though. The machine's front end is AutoCad. I need to make me some friends in mechanical engineering!! Have them design me up a fancy SVX keyfob... Maybe one in the letters of SVX with the S,V,and X being the keypresses!!
I'm starting to really take this serious..
Robert
Old 03-03-2005, 12:03 PM
CigarJohnny's Avatar
CigarJohnny CigarJohnny is offline
Send a message via Skype™ to CigarJohnny
I have the same problem with my remote(s). Sometimes it works great and other times I have to press it several times to get it to register. It usually works when once I find the sweet spot and press like hell. My original one had a split case from my fingers crushing it to make the switch respond. Then I got a brand new one (won it at last years meet) and it seems to be even crappier quality than the original. My third one (with the new SVX) is just as bad as the others. If you ever opened it up you would see that it is the cheapest POS that any car company ever produced. I can't imagine purchasing an SVX new back in '92 only to be handed this piece of garbage. The car really deserves a better remote. Hell, I bet even Hundai would laughed at this thing back in 1992 if someone would have told them to use it with their cars.
Johnny
Pearl '92 LS-L 179K (Historic 1st 5-speed SVX)
Mods: 5-speed, 4.11's, Group-N motor mounts, dual Magnaflows, cone air filter, Kenwood MP-228 CD/Receiver, white-faced gauges, '97 grill, custom window tinting.
Ebony Mica '92 LS 80K Oct 2002 - Dec 2004: Victim of theft. She served me well.
You can tell the lack of craftsmanship by the wrinkles in the duct tape.
Old 03-03-2005, 12:48 PM
Johnny
I most certainly agree. I took a look at the components and it reminded me of the old 80's style "radio shack" remote control car transmitters. The ones that cost $30 for the car and all. It's ridiculous!!
Robert
Old 03-03-2005, 05:33 PM
kuoh kuoh is offline
For just over $150 now, you can get a good aftermarket alarm+starter that has a pager and supports options like window roll up and trunk release. I never did spend the extra $$$ for the window modules, but the trunk release has been very handy.
KuoH
