Won't Start
Drove home from work (about 2 miles), parked the car, went back out 15 mins later to go to dinner, turn the key and nothing. There's a slight click that comes from the right rear of the engine (passenger side), and a sound that sounds like air or water running through a hose but the engine won't crank. Any ideas?
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 Last edited by SubaSteevo; 02-23-2005 at 08:34 PM. |
try going back out there and starting the car again and see what happens. Its happened to me before too. I know its a long walk but do it
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
The noise will be your starter solenoid clicking...probably because it's not getting enough power.
It's either a wiring issue or your battery is dead. If it's a wiring thing then if you keep clicking it should eventually start. It worked for me but then I put in a relay to channel power directly from the battery to the solenoid.
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 Last edited by SubaSteevo; 02-23-2005 at 09:09 PM. |
That's exactly what happened after mine had been sitting at the body shop. They took half an hour getting it out, and I figured out why later on.
I stopped at the wash, killed the engine, tried to start it up it just went clickclickclickclick. Made a call, got a jump, bam it started. Ran across town a few times. Drove for like an hour. Got home, killed it, let it sit a minute, started right back up no problem from then on. I have no idea why yours is doing it, though.
starter problem
I recommend you follow EARTHWORM's suggestion and use a relay to send full battery voltage to the solenoid.
Over a period of time plug-in connections to and thru the ignition circuit can become corroded and cause an minor voltage drop at each connection, thereby reducing the amount of voltage prior to reaching the solenoid. This can cause the solenoid to not receive enough voltage to actuate well enough to make the internal connection that is necessary to run the starter motor. This will be apparent with a weak clicking or no clicking of the solenoid. The Relay install will ensure full Battery voltage at the solenoid. Also the solenoid internal connection contacts for the starter motor may be worn down enough to not always make a good connection. (The solenoid will throw the drive gear forward but not rotate) This happenned to my starter recently. I was able to build up the worn areas with solder and that took care of the problem. I hope I explained that clearly enough to be of some help. TXCESSVX |
Re: starter problem
-Steve Member #895(the member formerly known as BurgundyBeast) 01' MSM Lexus IS300 |
You could always use the "screwdriver technique" to start it
On the way to Pep Boys to get a relay, have already cleaned of the connectors on the starter, next step is to check out the solenoid and install the relay. Hopefully it'll start, I've got tickets to motorcyle/atv ice racing tonight and of my 3 friends going, I'm the only one who even has a car.
