Old 10-30-2004, 11:46 AM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Question
Originally posted by soobiesvx93
i dunno i had mine flushed twice with no ill effects.
Mmmm hmmm....I'd say that if the technician knew what he was doing, the flush wouldn't be harmful and would sure beat using a case of fluid to get a 90% fluid change.
But...
Do you really trust that tech?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 10-30-2004, 12:11 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Significant Technical Input
Even if done right the tech's portion hasn't anything to do with the issues I mentioned above. Try going to a national chain like PepBoys or Valvoline Quick Lube, etc., you'll get the rundown from those that have been there.
Old 10-31-2004, 06:44 AM
I had my tranny flushed about 20,000 miles ago (at 60K) by my Subaru dealer and have not had any problems to date.
The SVX Master Tech told me that, like most good flushing machines, it uses the transmissions own oil pump to move the fluid. With the engine running, the old fluid is pushed out while the new fluid is drawn in.
Since there is no additional pressure used to flush, other than the trannys own pump, I wouldn't think there is anything that would disrupt or dislodge anything. It is just moving fluid at the same rate it always did, only the fluid is always fresh.
Old 10-31-2004, 09:18 AM
THAWA
it's not about whether the machine uses the trannys atf pump, well I guess it could be. The main thing is getting rid of the old stuff. For instance, the clutch packs and whatnot start to disentigrate, but there's still enough of the clutch material floating around in the atf to keep the clutches working, when you flush out the old stuff, there's not enough for the clutches to work.
Old 10-31-2004, 06:02 PM
SEA Sleeper
Originally posted by PA_SVX
Also look up the other thread where we discussed this. I had mine flushed with horrible results.
My transaxle fried 2 clutchpacks less than 30 days after I had it flushed.
I would advise not to have the SVX's 4EAT flushed.
Old 10-31-2004, 06:37 PM
THAWA
how was it cared for before hand though?
Old 10-31-2004, 07:09 PM
SEA Sleeper
I had recently purchased the car used so I cannot speak for that. It is VERY well taken care for since i's rebuild.
