how hight should a SVX be off the ground
I think my strut springs are weak in the rear.
can some one tell me how hight the car should be in the front and in the rear. on my car the top of the rear tire is just up inside the rear fender
I'm not so sure about the front and back individually, but I believe that the lowest point on the front bumper cover should have 5.6 inches of ground clearance (about 5 and 9/16 inches).
I actually asked mike this. Mine looks lower in the back than the rear but its because the rear wheelwell is flat on the top so it gives the illusion that its lower. Hope thats your case.
Sagging rear ends seem to be a common issue with SVXes. Could be the springs sagging, but it could also be something with the strut mount. The rubber cushion could be collapsing, or the upper spring seat could also be collapsing.
Here's a .pdf with the spec.
Um, how much does your stereo stuff weigh? That may add a little sagg.
well I don't know, but I what guess about 150-200 pounds.
I used 2/3 a sheet of 3/4 MDF to make the box.
Wheel Arch Height.
From the official Japanese RHD manual : -
Measurements from center and highest point under edge of wheel arch to the the center of the wheel hub. Front. 380 m.m. +10 , -20, or 14.96 inches + 0.39, - 0.79 Rear. 335 m.m. + 10, - 20, or 13.19 inches + 0.39, - 0.79
I guess I should just lower the front. going to need coil overs so I can set the back a little higher and the front a little lower.
ground controls and konis hopfuly next summer
That's what I'm waiting on!!! I'd like to make the car sit even or possibly a little lower in the front than in the rear but not noticably... Just want it to look perfectly level... Mine looks like it is riding on the rear bumper after doing the 5 speed conversion... We took nearly 160lbs off the front wheels with the conversion so I need that suspension to kinda level things out a bit...
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
Re: how hight should a SVX be off the ground
no mine are not rusted like that. I checked them.
the left rear one was but I replaced it with a used one.
