Old 03-27-2003, 07:10 PM
Subafreak's Avatar
Superbeast
God no, no holeshots. But still a viable posibility. It's an ATC pressure plate and I haven't been launching it at all but it's worth a look.
Old 03-30-2003, 03:28 PM
Subafreak's Avatar
Superbeast
OK so I pulled the tranny out today and found nothing unusual. The clutch was fine, the flywheel looked fine. So I guess either my motor is coming apart or it's normal?
Old 03-30-2003, 04:38 PM
Phast SVX's Avatar
Phast SVX Phast SVX is offline
BOOOOOOOOOOOOOOOOOST
Send a message via AIM to Phast SVX
no joke here , so dont push this aside. What did you do about spacing the shifter from the driveshaft? The bottom of the shifter assy may be tappign the shaft just the smallest amount. I cant explain it, but before i lowerd my trans a bit and the carrier i was getting the same feeling as you ddi going up hills. try putting 2 washers inbetween the trans crossmemeber, see if it goes away(make sure the shaft is still balanced) and if that isnt enough then maybe space the carrier as well(3/16" as huck recamended). i didnt need to drop the midshaft, but no joke: dont overlook this.
phil
~Phil
Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog.
Old 03-30-2003, 04:48 PM
Subafreak's Avatar
Superbeast
No not that kind of vibration. Besides I made my own crossmember and shifter linkages so plenty of room in there.
