Old 08-04-2008, 05:38 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Bad o2 make the car earthquake shake?
So after riding around for an hour or so.... the SVX sits parked for about 35 minutes while I go into the store. I come out, start it up and the entire car is shaking really really bad. chug chug chug chug chug....
Great... so finally the light comes up and the code gives me 32 - oxygen sensor... yet it seems like a spark plug is misfiring?
Should I just go ahead and replace the o2 sensors and then take it from there? Also, after driving it home (9 miles) I pulled the codes again then it gave me 32 and 56. Would the o2 sensor and driving on a bad one result in the code 56 maybe?
I don't see anything wrong with the exhaust or anything else so I dunno? Thanks for any input.... I've had the new radiator installed for a day, happy to be driving it again and then this pops up.... meh.
1994 subaru svx le 112k
Old 08-04-2008, 05:40 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Bad o2 make the car earthquake shake?
Its easy enough task to do. If you have the cash for O2 Sensor then get and replace it (sensors don't last for ever)
Old 08-04-2008, 05:56 PM
Subix's Avatar
That's the plan... but in the meantime my mind is still in wonder as to if this is actually the root cause and would make the car run that badly...
Old 08-04-2008, 06:06 PM
Rebuilding
Well has it done it again? Code 56 is EGR Valve stuck open or closed. I had my car shack really bad once on me car was cold and I tried to push it a tad bit and came to stop and it shock its self bad, and Car cut off. I let it sit for a min and started up fine and haven't had a problem since. Could have caused a problem but i'm not an expert I'm sure someone else will tell you.
Read here :P
If the problem repeats start with EGR valve then move to O2 Sensor it shouldn't cause it to shake like that.
Old 08-04-2008, 06:13 PM
Subix's Avatar
Read here :P
Well, that code hasn't came back... only the the 32 came back up after resetting the computer which is why I was asking... but yea, let it sit over night and starting back up it just shakes terrible and runs like crap.
Thanks for the link!
Old 08-04-2008, 06:15 PM
Rebuilding
Well, that code hasn't came back... only the the 32 came back up after resetting it all which is why I was asking... but yea, let it sit over night and starting back up it just shakes terrible and runs like crap.
I think its time to replace that sensor.
Old 08-04-2008, 07:22 PM
kwren's Avatar
kwren kwren is offline
I would do the EGR first Would also make sure the timing belt hasn't slipped.
Keith
Old 08-04-2008, 07:28 PM
Rebuilding
^^ THat is what I suggested :P Reading back now it might have came off as confusing.
Old 08-04-2008, 08:26 PM
kwren's Avatar
Sorry Guitar picker!
I am running around like a chicken with it's head cut off and didn't have time to read the stuff!
Take care,
Keith
Old 08-05-2008, 09:16 AM
as suggested, check the egr valve to be sure it is closing... You could simply just reach under while the car is running and try to move the valve with your finger to see if it changes the car's idle.
Old 08-05-2008, 09:27 AM
ShiuludeSVX's Avatar
Mine will do that sometimes, if I don't let it run for at least 10 seconds in the morning before pulling onto the road. Stop, and turn it off for 30 seconds and restart. It runs fine after that.
Yes, it feels like a plug is fouling to me.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 08-05-2008, 08:12 PM
Subix's Avatar
As ridiculous as this may sound (I'm really not a car mechanical person by any means... this appears to be changing quickly though) where exactly is the EGR valve located? I've looked at parts online and I've tried to pinpoint it but I'm no good with this stuff, honestly.
Where is the general location/area of the EGR?
Old 08-05-2008, 08:22 PM
kwren's Avatar
might look under the intake manifold. I think it might be there. Pretty sure
Old 08-06-2008, 10:07 AM
It is actually under the main wiring loom on the rear passenger side of the engine.
Old 08-06-2008, 03:02 PM
kwren's Avatar
Thanks Tom!
Always wondered where that rascal is!
Appreciated,
Keith
