Old 10-25-2005, 05:55 AM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
Diff lock questions??
Hi all
i was wondering if anyone could tell me the benifits of having the diff locked???? ( speed, accleration???) and what is the consequences of having it locked over time????
I ask because i had it locked for a half hour the other day, i found it to launch well, but it slid arond some wet corners, i was just wondering what actually happens?
I was thinking of installing a switch to turn it on and off, can this be done whilst driving???? any concequences???
cheers
Jake
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 10-25-2005, 07:14 AM
92SVXLS-LDC's Avatar
92SVXLS-LDC 92SVXLS-LDC is offline
in my audi 80 quattro it just engaged the rear wheels only... there was a button right by the e-brake...could be different? but it automatically turned back to quattro at like 15mph, i'm sure the subaru doesnt do that.. the only undesirable effect would be rear wheel drive traction and as long as you can easily switch it back, i'm sure its fine....Dont quote me! i'm guessing
'96 Saab 900 turbo
'95 Passat (drove the wheels off)
'92 SVX Ls-L (smashed/sold)
'88 Acura Legend (wheel fell off)
'90 Audi 80 quattro (50mph into side of truck)
'95 Saab 9000cse turbo (sold)
Old 10-25-2005, 08:27 AM
mbtoloczko's Avatar
sans SVX
It strongly couples the front and rear drivelines. Driving around on asphalt, it puts more stress on the driveline components and tires. Its no good for traction in the corners. During normal cornering, the front wheels are moving at a different speed than the rears. With the center diff locked, this will cause additional traction stresses that will make the front or rear wheels (which ever has the greatest load) to break loose more easily.
Mychailo
Visit my locker
Old 10-25-2005, 04:14 PM
Euro Diff lock fuse.
Yes JJ, Mychailo is right it is not for driving around with. It is there for runing the car on a 4 wheel dyno. It applies the Limited Slip Clutch in the center diff, to lock the drive to the front/back together, so it won't shunt on the dyno rollers.
Driving with the fuse in will cause binding, what will cause wheels to break traction to unwind the drive line. Thats why it moves around when cornering, the drive line is trying to unwind. There is no advantage in doing it, it could end up damaging the clutch.
Old 10-26-2005, 04:16 AM
-JJ-'s Avatar
Endangered Species
ok i wont bother, thanks for the answers guys
one last question?
Does it improve 0 - 100 acceleration times????
Old 10-26-2005, 04:29 AM
one last question?
No JJ, its better off with the normal 36front/64rear, than 50/50.
Old 10-26-2005, 09:07 AM
-JJ-'s Avatar
Endangered Species
thanks Harvey
