Old 10-08-2002, 10:34 AM
$VX
Rattling brakes
Well, I have new pads and new rotors, and I installed the shims on both pads...but they still rattle. Yes, they rattle less, but it still makes a noise when I go over bumps (unless I have the brakes on). Anyone know how to stop this?
- Ca$h
Old 10-08-2002, 10:52 AM
lee lee is offline
I have never tried this, but I have heard of people putting some type sticky adhesive on both sides of the shim to hold the pad against the piston/caliper. Sorry, even if it works, don't know where to source either.
Old 10-08-2002, 12:11 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
You did not say if these are OEM pads or not so I will ask.
Are they OEM pads that come with new shims or are you re-using the old shims?
If you buy aftermarket pads, you need to replace the shims at least every other brake job. You can buy shims individually under these part numbers:
Qty 4 26233PA030
Qty 2 26233PA050
If ypou look at the drawing:
http://www.subaruparts.com/diag/?mod...category=262-A
You will see that there are two inboard shims and one outboard shim.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 10-08-2002, 01:47 PM
Mr. Pockets's Avatar
Moderator
Something only just now occured to me. The center caps on my wheels rattled until I bent their brackets outward a little for a tighter fit. Could this possibly be the rattle you're hearing?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 10-08-2002, 01:51 PM
$VX
I bought some Raybestos BRUTE FORCE pads. They came with TWO shims, so I put on on the outside pad, and one on the inside. So I need another one on the outside? Weird. I recall someone talking about some loose bolt or something that it could be.... but I tightened everythign I could so I doubt that.
- Ca$h
Old 10-11-2002, 12:36 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Right on. It's called anti-squeal compound and frequently comes in a little plastic squeeze packet with the new pads.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 10-11-2002, 12:50 PM
mattski mattski is offline
And sometimes that little packet is grease to put on the ends of the pads where they ride on the guides. Confusing the two compounds would result in problems.
Mattski
97 LSi Ebony Pearl 130k Midlife Crisis
93 Legacy Wagon 180k Training Wheels
98 Outback 180k
98 Dodge Durango 120k Ski Bus
A multitude of skis to feed my need to go faster, faster until the thrill of speed overcomes the fear of death.
Old 10-11-2002, 04:10 PM
sfsvx's Avatar
Definitely - don't be like the aircraft mechanic I know that picked up the Loc-Tite instead of the anti-seize compound. VERY different results, none favorable.
Dick
2001 Outback Sport
Old 10-11-2002, 08:10 PM
DWayne2910
Using the wrong compound
Dick:
Also reminds me of the guy who didn't know the difference between Vaseline and putty...
Dan
(All his windows fell out.)
Old 10-11-2002, 09:09 PM
sfsvx's Avatar
Re: Using the wrong compound
Originally posted by DWayne2910
Dick:
Dan
Dick
2001 Outback Sport
