Old 01-04-2010, 05:27 PM
**Ewie**'s Avatar
**Ewie** **Ewie** is offline
Aussie in enemy territory
Rear Combo Light - Fixing Leaks
Well in an attempt to fix the leaky brake light syndrome and after researching here for some time, I bought a new set of gaskets and today removed one of the offending lights. To my surprise, there's absolutely no evidence that moisture has been getting past the existing gaskets and on closer examination, I believe it's getting in through the holes where the red acrylic lens "snaps" into the main black housing. I'm assuming therefore that the problems is actually failure of the seal/glue between the lens and the body itself.
My question is, has anyone ever removed the lens from the main housing before? I'd like to know it's posisble before I go and destroy an otherwise good light unit.
Old 01-04-2010, 06:41 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
Re: Rear Combo Light - Fixing Leaks
http://www.subaru-svx.net/forum/show...ht=oven&page=6
READ THE POST #14
(AT YOUR OWN RISK)
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 01-04-2010, 07:06 PM
**Ewie**'s Avatar
Thanks for that, also saw the lobster pot boiling idea as well. I think I'll see if I can get a couple of spare lights before I attempt this though....
Old 01-04-2010, 07:18 PM
MadMaxSvx's Avatar
Well, i will try the oven procedure in my tail lights, they have moisture and dirt on them and its time of doing something, i hope the result is good.
95´ Subaru SVX EURO
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
69' Mustang Hardtop
Old 01-05-2010, 01:33 AM
I have never seen any reason that the gaskets didn't keep the water out, but after replacing them, it stopped the problem. Don't tighten the fasteners too tight when you put them back on. That can cause the problem as well.
Old 01-05-2010, 02:26 AM
**Ewie**'s Avatar
Thanks Earl.. I have brand new gaskets ready to go in.. rightnow I've got both light units stored in our hot water cupboard, the warmest/driest place in our home, so that they will dry out completely. Hopefully they'll dry out overnight and I'll fit them tomorrow. Would it help to use any sort of water repellent sealant or grease on the gaskets as well??
