MAF problem
1994 svx
intermittantly stalling Replaced cam shaft sensor, fuel filter, new grounds on car Finally broke down and bought a new MAF Just installed it. Car starts, idles rough and then dies. Restarts immediately and does the same thing. If I unhook the sensor connector the car runs fine. Oh and I already took the old one in for core. Any thoughts. Does the car need to learn the new sensor? |
Re: MAF problem
Yanked the MAF back out. Cleaned it with MAF cleaner and reinstalled it. Car running fine now.
Don't know if the sensor was dirty (not a great thing to do sending a dirty sensor) or if the car finally caught up with the new sensor. Gonna let it run for a while before I try driving it. |
Re: MAF problem
ok so i am at the end of my rope. After the car started yesterday it ran well to work today. Coming home the check engine light came on. Initially ran well. It then shuddered and lost power all together. Car then died with all dash lights coming on. Car restarted but would immediate sputter and die. Did this 5 times. Finally got out and unhooked the new MAF. Car immediately started. Check engine light is on but car drove fine the rest of the way home.
A couple of questions: 1. any ideas what is going on. Seems like the problem is with the new MAF. Not sure why it initially didn't work, then worked and then crapped out again. 2. At this point I am willing to drive around with the MAF unhooked, not sure why it drives so well with it unhooked and what damage I might be doing. 3. I get 48 hours to fix or the wife says the car has to go. |
Re: MAF problem
Check your air filter. My MAF got coated pretty well from smoke under the hood (long story) getting through my K&N. I cleaned it up, and it ran great, but I still used it as excuse for my lady to upgrade to ECUTune stage 2 with a new MAF. Haven't had a problem since. But if your MAF keeps getting dirty check to make sure it isn't a filthy filter, or torn, allowing your sensor to keep getting coated.
Otherwise, your gremlin seems electrical. Check for condensation on the harness pins as this could also cause some nasty problems.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor Buying parts is like car payments. Someday she'll be all mine. |
Re: MAF problem
Brand new air filter, stock air box
Re: MAF problem
Are you getting any codes? Where in Iowa are you, by the way? I too, am from the tall corn state! lol
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Re: MAF problem
New MAF sensor in. All the problems fixed. Frustrating when you are sent a defective part.
Re: MAF problem
Well, that's good news then! And yeah, that does suck getting a defective part.
Re: MAF problem
10 characters.
Re: MAF problem
Autozone online. It was a remanufactured part from cardone.
Re: MAF problem
I had this stalling problem, checked the code and it was air flow meter(MAF). I tried to go cheap and get a used one from a salvage yard(never again). I found out it was bad after I broke down and bought a new one from Subaru and it cranked right up.
Mike
95 Pearl Blue L |
