Old 11-20-2003, 12:53 PM
mark10t
Dash Lights
Some of my dash lights have seemed to quit working, so I thought I'd take an informal survey to see what dash lights actually have the pale green backlighting before I tear the dash apart to attempt a fix.
In the 'CRUISE'/'FOG LITES'/'SECURITY' cluster- only my 'FOG LITES' switch is backlit.
In the 'HEATED MIRROR'/'PARKING LITES' cluster- only my "PARKING LITES' switch is backlit.
In the 'REAR DEFROSTER'/'4-WAY FLASHER' cluster- nothing is backlit.
In the dash-mounted 'PRND321' indicator- all positions light up EXCEPT the 'D'.
Gentlemen (and ladies)- what bulbs need replacing? (What's lit on your dash that ain't lit on mine?)
Thanks for your help!!
-Mark
Old 11-20-2003, 01:05 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Every one of them is supposed to light up. There is a recent thread on what kind of bulbs goes into which.
Also, to do the PDR123 in the dash, go to the link under my signature and click on how-to.
L
Lwin M. Maung (Member # 147)
Current SVX: • NONE
Other current cars:•2001 Jeep Grand Cherokee Black
Old 11-20-2003, 03:19 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
My 'D' didn't light up for about 2 months. Then all the sudden it started working again. Loose connection I guess. Very strange though.
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 11-20-2003, 04:54 PM
I am also missing many lights.
On my tunnel console the gear selectors all light up but the "N" is brighter than all the others. Is that normal?
Old 11-20-2003, 05:17 PM
mark10t
<<On my tunnel console the gear selectors all light up but the "N" is brighter than all the others. Is that normal?>>
That one I can answer, because I just had the console apart- there is just one bulb that illuminates the entire console. You've probably got a bulb that's not positioned correctly in the holder.
-Mark
Old 11-21-2003, 11:45 AM
ou2mame
on my actual shifter, the backlight doesn't work period.. none of the button's dash lights work besides the fog lights, plus my door's sensor is broken so there's no interior lights either because if i had the bulb in, it'd look like a disco. oh, and the buttons for the maplights and stuff also aren't backlit.
Old 11-22-2003, 09:03 AM
calmone
the "D" on the dash of mine also stopped lighting up for a few months and the began working again. maybe it was some kind of virus going around.
i still don't understand the tape player, or specifically why there is no light telling me which track is playing. is there supposed to be one or is it some subaru kind of jest?
Old 11-22-2003, 02:18 PM
svxeno
this is supposed to light up but it fails on a lot of the units. It's a selling feature when you have one that the light works. So don't feel lonely.
Randy ii
Old 11-22-2003, 03:21 PM
JLittell
Looking at Subaruparts.com trying to figure out which replacement bulb is which for the cruise/fog/security. 'Security' shouldn't be needing replacement.
http://www.subaruparts.com/diag/?mod...category=830-1
Please correct me if I'm wrong:
Subaru Bulb Replacement: 83426PA020
Subaru Bulb Replacement: 83426PA030
These diagrams are quite difficult to read!
Are these factory bulbs identical??
Old 11-22-2003, 04:17 PM
John
I will agree with you on that one - they are hard to figure out!
I did figure that 020 and 030 are different.
There are three bulbs that they show.
1) 83426PA010 $4.53 ea (2) total
2) 83426PA020 $1.49 ea (6) total
3) 83426PA030 $4.53 ea (4) total
I don't know the difference between 010 and 030 though.
If I ever get this figured out, I will post a list on the how to locker of all of the lights and numbers. This is about to make me go mad. Maybe Lwin can give us the equivalent numbers for Radio Shack.
Old 11-23-2003, 08:17 AM
JLittell
I can see where the 83426PA020 and the 83426PA030 go. Has anyone had this panel apart to verify that the bulbs are different? Pics are good too!
Old 11-24-2003, 10:23 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
The switch panels pop out and the lamps screw into the top of each switch. The only difference I can see is that the 030 is probably for the emergency flasher and comes with a red rubber sheath covering the bulb??? Other than that and the color of the plastic base (which really ends up at the TOP of the switch) I don't think there is a difference.
Now, can someone tell me how to get the cover off of the lamps at the roofline for the map lights? I really dont want to screw that up when I attempt to change those illuminating switch lamps.
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 11-24-2003, 10:42 AM
JLittell
Does the dealer factory bulb replacement include the blue sleeves/ condoms then?? This is all driving me crazy!! Can someone help here?? Lwin?
Old 11-24-2003, 10:45 AM
Nope, Unlike the REAL world...you must reuse them or just go without. I opted to go without and have seen no problems as yet.
"NEW" VISORS
'05 Outback 3.0R
Old 11-24-2003, 10:58 AM
Seraph's Avatar
The boots have to be purchased for a different vendor. Dealer does not carry them. If you use them without the boots, it will be brighter since the plastic already has green tint as well.
Current SVX: • NONE
