Old 10-18-2012, 01:56 PM
Mitsubishi wheels
Will 2008 Mitubishi Spyder wheels fit with 215x 60x 17 tires and are the lug nuts compatible. Info says tires are 1" taller than stock 225 x 50 x17
Got a good deal for winter tires.
Old 10-18-2012, 02:00 PM
bishop bishop is offline
Re: Mitsubishi wheels
wheels appear to be 5x114 so they should fit, not sure about the 215x60 though.
Old 10-18-2012, 03:41 PM
All depends on the offset of the rim...
Old 10-18-2012, 05:00 PM
The Internet spec say the Mitsubishi Spyder Gt is between 35 and 40
Old 10-18-2012, 07:13 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
why do you insist on creating a new thread for little questions that are for the same item?
Way to use up bandwidth.
I should create a thread because I thought of something that I thought of last week.
