Old 04-12-2012, 06:29 AM
Jvan Jvan is offline
will 245/40/18 fit
Looking at some Yokohama S Drive 245/40/18 tires on Craigslist that seem to be a good deal. Will they fit the SVX? I had been searching for either a 245/35/18 or 225/40/18 but those sizes appear to be scarce.
Old 04-12-2012, 06:47 AM
Re: will 245/40/18 fit
What offset are the wheel? They're a bit taller than stock. You may get some rubbing in the rear depending on the condition of your rear suspension (if it's soft or sagging).
Old 04-12-2012, 10:45 AM
Not sure of the offset but the wheels are from a 07 Subaru Tribeca.
Old 04-12-2012, 11:19 AM
Looking at another tire Dunlop 8000 in 245/45/18. Between the Dunlop and Yokohama S drive, any preference?
Old 04-12-2012, 12:19 PM
I wouldn't go as tall as 45... That's ~2" taller than your OEM tire size. 245/40 should be a good fit on Tribeca wheels, I believe they're 8" wide.
Old 04-12-2012, 05:05 PM
I'd go with the Yokohama S Drive. I have the W Drive for winter.
Old 04-26-2012, 08:39 PM
Put on the S drive and they fit with no problem but it is close to the strut. Only problem is I used the original chrome lug nuts from the SVX and they are too long to fit the center caps for the Tribeca rims. Should I just buy generic short lug nuts from the parts store since the cap will cover them or buy Tibeca/aftermarket tuner nuts?
