Old 10-11-2011, 06:25 PM
Chris_'s Avatar
Chris_ Chris_ is offline
Does these 18x9 fit?
What you think about fitting 18x9 offset 51 front and offset 38 back ? Does those fit? I have rear camber bolts too if those help. And yes I know those arent best for the daily driving, those would be my "show off" rims if I decide to buy those.
svx my94 vtd EUDM
-custom Spax coilovers
Old 10-12-2011, 04:44 AM
Chris_'s Avatar
Re: Does these 18x9 fit?
Those are Work vs-xx 3-piece (a-disc I think).
svx my94 vtd EUDM
Old 10-12-2011, 05:37 AM
In all likelyhood you're going to have to find out to for yourself, there isn't too much experience here with the more aggressive wheel fitments. You're going to need some fender work in the rear - rolling and removing the rubber strip along the wheel well edge, and maybe spacers in the front to keep the wheel off the strut.
That's all best guess though... Your mileage may vary.
Old 10-12-2011, 08:53 AM
I would say NO , But I have a buddy with a hot wrench ( cutting torch ) that will make adjustments and D get them to work
Old 10-12-2011, 09:25 AM
92 SVX 92 SVX is offline
with a 9 inch rim I would say the rear with a +38 will be a tight fit the fronts should work but full turn may have some rubbing.
