Old 06-08-2011, 02:08 PM
nexus_7 nexus_7 is offline
my 4.44 is acting up...help
Bud did my conversion 2 or so years ago, and just last week now it has started having real slow shifts between 2-3 and 3-4. Up reving and what not with out shifting unless I ease off.
I did the trans code check cause the power light was blinking 16 times on start up...but after finishing the code check the power light just keeps flashing I got to about 145 and quit.
What do I do?
Thanks
Greg
Old 06-08-2011, 03:01 PM
Re: my 4.44 is acting up...help
Whatever code is in the system will not tell you that the high-clutch in the transmission is worn out. The more you rev, the worse it will become.
Old 06-08-2011, 03:03 PM
so, what do I do? replace the trans?
Old 06-08-2011, 04:11 PM
Yeah I think so. Better give Bud a call maybe you can get it to him before it needs to be towed.
Old 06-08-2011, 04:56 PM
What do I do?
Thanks
Greg
There must be a code, if the light flashed on start-up. The continuous flashing says no code, at the moment, but there may be a code in the memory. Check there to see.
