Old 06-07-2011, 08:00 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Will this used harness work? Need confirmation
The first picture is of my current harness removed from my vehicle (under intake manifold) It is only missing one pin in the corner of the connector.
I picked up a used harness from another member on the site and now not sure if it will work because it's missing a few more pins on pictures 2 and 3.
Question 1) Will the used harness with missing pins work?
Question 2) THe used harness has a gouge in the wire in picture 4...what's the best way to fix this? Just add a little solder?
Please advise
Thank you.
1995 Subaru Svx L / AWD
Old 06-08-2011, 04:11 PM
msvx95's Avatar
It's just a phase
Re: Will this used harness work? Need confirmation
I guess no one knows...looks like I will slice and splice.
Old 06-09-2011, 09:21 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
I could probably scare up the electrical diagrams of the harnesses and let you decide. You probably have a 92 version and then a later version from an OBDII setup. Later models had a couple changes with the additional 02 sensor coming to mind as an example.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
