Boots on struts
Are these supposed float freely, stay up on the strut shaft or stay all the way down on the strut shaft? If they are supposed to stay up or down, what holds them in place?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Boots on struts
Come on, nobody has an answer for this?
Re: Boots on struts
mine stay at the top of the strut. it latches onto a ring on the bottom of the bearing plate with teeth on it. you have to rotate it so it can slide over the teeth and then turn a little so it will hang. i don't know if my struts are original but i believe they are b/c i only have 78k on the clock
Re: Boots on struts
Ya' know, I've done 3 Koni conversions and replacements, and never been able to satisfactorily secure those boots. I was hoping to hear definitive answer, as all the ones I've done they basically self-adjusted position determined by bump-stop position on the strut shaft. 2 of the conversions included new top-mounts (oem), bump-stops and all rubber spring cushioning. I have the FSM's and nothing in the book resolves the issue. I'll admit to
Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Thread Tools | |
Display Modes | |
