Old 05-13-2011, 05:14 PM
teamilluminata teamilluminata is offline
Iris Valve Verification
I suspect my IRIS valve is faulty as I am getting stumbling and hesitation upon acceleration between 2000-3000rpm. I know there are other possible causes but want to rule this out.
I have read, probably on this forum that it is open at idle, closes at about 2000 and opens again a little above 4000rpm. I've also read that you can check the opearation by watching the actuator move while operating the throttle by hand. I've tried this but can not see enough under there to tell if anything is moving. I can snake my hand under there and feel the actuator rod but I only felt it move slightly when blipping the throttle quickly. It hasn't moved yet while reving the engine but I can't do that and see the tach so I don't know how high the revs get but it is bllody loud and hot. I also don't know which position is closed and which is open. My rod moved slightly towards the drivers side when I blipped. Is this opening or closing the valve?
Any other tricks to checking this thing?
Old 05-13-2011, 07:45 PM
Re: Iris Valve Verification
I hope that this helps.
http://www.subaru-svx.net/photos/use...svxfiles|29830
Old 05-14-2011, 05:33 AM
A little, thanks.
Old 05-16-2011, 01:37 PM
macadamianut macadamianut is offline
I'm far from an expert on these cars, but I'd be happy to lend what knowledge I do have. I'm just up the street from you in Auburn Hills. I have been through the IRIS when troubleshooting another problem I had.
Mac
__________________________________
1995 SVX-L AWD, green, 98,xxx miles, ECUtune 1.5, mazda RX-8 wheels with subie center caps, stebro muffler, resonator delete, koni inserts, perrin crank pulley, hella 500 off-road lights, power-slot rotors and .....
1993 968 Coupe 6-speed, 80,xxx miles black, H&R springs
Old 05-16-2011, 05:07 PM
The IRIS valve won't cause the problem that you are having. If the valve was not working, the torque below 4000 would be low, but would run ok.
If you are getting some reaction when you blip it, its working.
Old 05-17-2011, 09:02 AM
That's not what I wanted to hear. I want something I can fix
What else could do this?
Old 05-17-2011, 09:44 AM
dennyo dennyo is offline
don't worry.this car will give you plenty of opportunity's to fix things. trust me.
