Old 04-02-2011, 02:57 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
PCV hose
Having trouble removing the PCV hose off of the valve. It's on there good and unable to turn the valve any more to loosen it. Screwdriver to try to pry off the hose not working. Any good techniques?
1995 Subaru Svx L / AWD
Old 04-02-2011, 06:02 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
Re: PCV hose
Do it when the car is hot or heat the hose up a bit with a small torch
Old 04-02-2011, 06:30 PM
msvx95's Avatar
It's just a phase
Re: PCV hose
I would say I'm bound to burn my arm on the intake manifold if I do that, but perhaps it needs to be a warm hose.
Old 04-02-2011, 06:45 PM
Cam Cam is offline
Re: PCV hose
You need to get the hose to twist on the valve to make it easier. I would use a pick or small screwdriver to pry back the hose, spray some WD-40 into that bad boy, and keep cranking, it should come eventually.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-02-2011, 06:48 PM
msvx95's Avatar
It's just a phase
Re: PCV hose
I would if the hose didn't want to start spitting and breaking apart were I insert the tip of the screw driver
Old 04-02-2011, 06:52 PM
Cam Cam is offline
Re: PCV hose
Sounds like it's time for a new hose... it's not that hard to replace once the old ones off. Maybe it's a sign that you should replace all your vacuum lines and remove the intake manifold.
Cam
'92 Ls-L Dark Teal
