Old 04-01-2011, 11:08 AM
oregondave oregondave is offline
'thunk' when shifting into reverse - only when cold
Transmission shifts great otherwise, has external cooler and the quick change shift kit. once car is warmed up 2-3 minutes it shifts into reverse without problem. When cold it 'thunks' and it doesn't seem smooth going into reverse. no problems with other gears ever. Trans mount? Or is line pressure bad when cold?
Thanks as always,
David
Old 04-01-2011, 01:58 PM
Re: 'thunk' when shifting into reverse - only when cold
bump por favor - would appreciate thoughts on this.
Old 04-01-2011, 04:51 PM
You've gotta give more time than a couple hours for a response...
It could be the rubber in the mounts showing age, could be a number of things. Can you hear the clunk and where it is coming from or do you just feel it?
Old 04-01-2011, 05:08 PM
LOL well it was three
You're right sorry.
I think it's a combination of sound and feel.
Old 04-05-2011, 01:33 AM
Any thoughts folks?
Old 04-05-2011, 07:49 AM
Originally Posted by oregondave View Post
Any thoughts folks?
girlz are hard to understand.
Old 04-05-2011, 08:37 AM
processengr's Avatar
The rear differential rubber mounts, when shot, make that sound when shifting into reverse...very carefully, with parking brake on, maybe wheels chocked, look under rear of car, at the mounts, while someone shifts into reverse...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 04-05-2011, 03:01 PM
lol what does that mean Tom?
Old 04-05-2011, 03:09 PM
...they'll move?
Thank you!
Old 04-05-2011, 03:17 PM
If the rear diff mounts turn out to be the problem, I have an awesome fix for you: http://svxworldforums.com/view_topic...65&forum_id=13
The subframe bushings aren't necessary, and you don't have to cut away as much of the diff bushing inserts as that guy did. Just cut a little bit at a time and try to squeeze them in there until they fit. I have been running these on my blue car since the 6-speed swap and they're great.
Old 04-05-2011, 03:33 PM
Excellent sir. What is the benefit of doing this? Stiffen things up?
Old 04-05-2011, 04:32 PM
YOU said"Any thoughts folks?"
So I said what all us guys were thinking!
Old 04-05-2011, 04:34 PM
The Fifteen Minute Mod actually does a better job ot lesening the movement and its easier and cheaper!
However the bushings are up tp $7.99 each now so its now $16.00, plus tax.
Old 04-05-2011, 10:51 PM
The 15 minute mod will help too, depending on which part is wobbling, but that set of bushings comes with some inserts you can use to do basically the same thing, so you can kill two birds with one stone basically.
The diff insert bushings stiffen things up quite a bit. If your bushing mounts aren't completely trashed they are a decent alternative to replacing them (those are a massive PITA for the DIYer).
Old 04-06-2011, 01:35 AM
I'm confused. All you guys thought that me asking a question had something to do with 'girlz'? Your humor is going right over my head here bro.
