Old 03-29-2011, 08:35 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
5spd chatter
so as some as you may have read, i have done the 5spd swap with a 99 impreza trans and am having problems.
re-cap: the car can move and hit highway speeds, it shifts fine in all gears, and i replaced the clutch and pressuree plate with a ACT kit that can handle 308ftlbs of torqe.
problem: it could seem that the clutch slips howver i dont smell clutch after driving (troubleshooting) around for about an hour or so. 3-5 work almost flawlessly, but first and second are real sluggish. rpms shoot up and speed does nothing for awhile. tryin to hop in traffic wouldnt work well untill i get to 3rd lol
i took the clutch out to ensure it wasnt put in backwards and after veryifyin that, i adjusted and readjusted the clutch cable and the car does the same thing for the most part.
when stepping on the gas in every gear (letting all ponies and torque loose) there seems to be a litte slippage in 3rd -5th and little of "chatter" from the tranny and alot of both in 1st and 2nd....any ideas? viscous coupler?
thanks in advance
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 03-30-2011, 05:19 AM
Re: 5spd chatter
Mis-matched rear diff?
Old 03-30-2011, 07:43 AM
Manarius's Avatar
Manarius Manarius is offline
Re: 5spd chatter
160hp-designed 99 Impreza Glass 5MT not meant to handle a beating from 230/228 ??
-Jason
-Obi Wan Kenobi
Old 03-30-2011, 08:07 AM
Re: 5spd chatter
I've run Impreza 1.8 5-speeds on every 5-Speed SVX I've had and have had nothing but good luck out of them....granted I'm not a "Boy Racer" but do drive them spiritedly.
Clutch dumps are what kills manual trannys
Old 03-30-2011, 08:10 PM
VICSVX's Avatar
Never Forget
Re: 5spd chatter
im not a "boy racer" either, just like having the sporty feel...i have my wrx for speed lol but anything you can think of to solve my problem?
VICSVX
Old 03-30-2011, 08:26 PM
Re: 5spd chatter
You didn't verify my first thought about the mis-matched rear diff.....
Next thought would be a bad center diff...
Old 04-01-2011, 03:55 PM
VICSVX's Avatar
Never Forget
Re: 5spd chatter
hcuk369, the diff came from the same car so it cant be mismatched...how do you chekc the center?
VICSVX
Old 04-01-2011, 07:23 PM
Re: 5spd chatter
I don't know a good way to check it.....but it can be replaced with the tranny still in the car....
Old 01-09-2012, 03:17 PM
VICSVX's Avatar
Never Forget
Re: 5spd chatter
still stumped....i havent taken out the center diff (VC) to see if its work or broken...yet i still cant find a real good answer to my question.
VICSVX
Old 01-09-2012, 04:54 PM
jeffs92svx jeffs92svx is offline
Re: 5spd chatter
Did you get the flywheel turned? Everytime you put in a new clutch you have to get the flywheel turned or it will chatter and jump upon acceleration. That sounds like to me what has happened. i had to take my tranny back out after my first clutch job when i was young and get the flywheel turned and then it was perfect. You have to turn the flywheel so that the new clutch will mate to it. If it wasnt turned it is mated to the old clutch where it was burned in. Mated isnt really the right word but the clutch will burn in and when putting in a new clutch, all the old material and grooves have to be taken off the flywheel to make it smooth again.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS
Old 01-16-2012, 09:05 AM
VICSVX's Avatar
Never Forget
Re: 5spd chatter
Might have to give it a whirl... I can't figure it out and the vc I will take out too. I might just scrap the car cause whoever had it before me did some hack job to get the 5sp in. If trans is good I might keep it tho
VICSVX
Old 01-16-2012, 02:43 PM
THE NEW GUY THE NEW GUY is offline
Re: 5spd chatter
was your car automatic before?
what did you do with the auto transmission?
Old 01-16-2012, 06:02 PM
Re: 5spd chatter
This can't be a serious question...
Old 01-16-2012, 06:21 PM
VICSVX's Avatar
Never Forget
Re: 5spd chatter
Lol all SVX's were automatic at one point. And I bought the car with the manual
VICSVX
Old 01-17-2012, 06:17 AM
92 SVX 92 SVX is offline
Re: 5spd chatter
I think he was asking if you had done the swap.
