Old 03-20-2010, 02:03 PM
jjanak79's Avatar
jjanak79 jjanak79 is offline
crank
can i use a impact gun to get the crankshaft pulley off? I need to know right away. and thanks in advance for the help.
94 Subaru SVX FWD 51k
04 Mazda B4000 (work truck)
Old 03-20-2010, 02:09 PM
kwren's Avatar
kwren kwren is offline
Re: crank
Long break-over bar, socket and use the starter.
Old 03-20-2010, 02:22 PM
jjanak79's Avatar
Re: crank
a impact wont get it off?
Old 03-20-2010, 03:02 PM
siceclipse's Avatar
siceclipse siceclipse is offline
Re: crank
yes it will, but its just so much easier to use a socket on a large breaker bar and have a friend crank the ignition over while you hold the bar steady.
Mike
1992 SVX LS-L Pearl White 102,000 miles (Gone)
2005 Evolution 8 SSL Tarmac Black (new daily)
1995 Eclipse GSX Durango Copper Pearl (teh beast)
276awhp/280awtq @ 18psi (560's inj)
260awhp/260awtq @ 17psi (stock inj)
Old 03-20-2010, 03:09 PM
NiftySVX NiftySVX is offline
Re: crank
THIS IS EXTREMELY DANGEROUS AND I AM SHOCKED ANYONE WOULD DO THIS
Buzz it off with the impact
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 03-20-2010, 03:15 PM
siceclipse's Avatar
Re: crank
WTF? Dangerous? You mean like for the same dangerous the shop manual has in mind when it tells you to disconnect the neg terminal on the battery to change a tire dangerous?
I use a 1/2" breaker bar thats 3 feet long, then I take the end of my floor jack (another 3foot section of steel tube) and put that over the breaker bar for extra leverage.
2 clicks from the starter with putting barely ANY resistance on the breaker bar and the bolt is a full turn loose.
This should go without saying but when i was doing it the car was completely together. (A/C condenser, radiator, fans) and i had no room for an impact gun.
Mike
Old 03-20-2010, 04:09 PM
Re: crank
+ 70!
Hey, when its size five, and in RED, its important!
Old 03-20-2010, 04:31 PM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Re: crank
Well, how are you going to get it back on with the proper torque??? Seems to me you would use the same method. Yes, you can use the impact wrench to take it off, but you can't put it back that way.
+1 Using the starter is not a smart solution.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 03-20-2010, 04:42 PM
Re: crank
No this is dangerous in the fact that even a high quality tool could fail and come flinging off, this is just a bad idea. I would never even have thought of doing it this way. I always just use a chain wrench and a breaker bar and it comes loose. This is the tool I would use on it and I make a living doing this sort of thing. The proper tools make sure no one gets hurt. The starter is capable of serious torque and a standard chrome socket could shatter. If it was an emergency and you were inside the car and you had a snap on or similar impact socket on it, and the breaker was a good one...nope still wouldn't recommend it.
I'm not trying to condescend, I just don't want anyone to get hurt. Not to mention, why pull a stunt like that if they can just put an impact on it? Buzz that bolt off, I'm sure the poster already did. Just don't put it back on that way. I've seen a broken crank snout on a subaru and it's not pretty.
Old 03-20-2010, 05:38 PM
Re: crank
Use a flat blade driver of the proper size to jam the teeth on the flywheel/torque converter. Then use a large breaker bar to crack it loose... Remove the driver and use it on the opposite side to re-torque the bolt. I insert it between the exhaust manifold and the oil pan... Just be sure it is a good fit in the teeth less you want to pull the trans to replace the parts you broke a tooth on.
If you really want to get it right, Tim's brother is selling the special tool that is meant to hold the crank pulley... But its like $250... So, up to you
Edit: Also, do not use anything through the timing hole on the back of the block to jam the felxplate... You will damage the flex plate
Old 03-20-2010, 05:42 PM
Re: crank
BTW I giggled a little when I read the title
Old 03-20-2010, 07:59 PM
kwren's Avatar
Re: crank
using the starter, though frightening the first time, is a fantastic and safe way to do it. I just slide a plastic pipe over the handle of the break-over and let it rest on the fender and crank away! Works like a flash.
Any other way is a waste of time...
Please select the proper fender
Keith
Old 03-20-2010, 08:20 PM
Cam Cam is offline
Re: crank
Keith
Please...I mean come on, really? A safe way? I can think of many things that could go wrong. Most of them involve injury. Not to mention (which it already has) that you still need to properly torque the bolt. Just because it works does not make it safe. Words should be chosen carefully when posting things that can affect someone else's safety.
Edit: I have read of someone successfully drilling 4 holes in a 2x4 to line up with the four holes in the pulley. Then they drilled a big hole (probably used a hole saw) in the middle for the socket to pass through. They inserted 4 bolts through the 2x4 and pulley, and used it to back up the pulley as they removed the bolt. MUCH SAFER! (though more time consuming)
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-20-2010, 09:54 PM
kwren's Avatar
Re: crank
This is a simple IQ test...
Keith
Old 03-21-2010, 12:20 AM
Re: crank
According to subaruparts, you can get the proper tool from Subaru for a whole lot less.
499977000....Wrench Cp Crank Puly....List $95.55....Net $72.81
Too good to be true
. That particular part has been discontinued and the part number is superceded to 499977300A.
Different design and a higher price. Click HERE and HERE
