Old 03-19-2010, 11:45 AM
Paulrio74's Avatar
Paulrio74 Paulrio74 is offline
Removing window coating
I tried to search, didn't get any hits. It seems the consensus is that the titanium dioxide is a coating on the inside of the windshield. Has anyone tried, or have a guess, if it could be ground/polished off? I'd like to make a little radar "window" on the window. Any thoughts? My glass is good, not interested in replacing it with a non coated one. If there aren't too many you're an idiot there's no point replies, I'll try it and give a result update.
Old 03-19-2010, 11:56 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Re: Removing window coating
I always thought it was just built into the windshield.
Old 03-19-2010, 12:23 PM
Green1995SVX's Avatar
I believe it's part of the lamination between two layers of glass.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-19-2010, 01:34 PM
Don't a lot of radar detectors work even with the coating?
Old 03-19-2010, 01:45 PM
Freeman's Avatar
Unregistered User
I was pretty sure they still work regardless.
Old 03-19-2010, 01:59 PM
Paulrio74's Avatar
Mine doesn't, at least well enough to trust. I'm looking at another, but I want to test if this could be a simple fix. Everyone seems to refer to it as a "coating" on the net. I figure a bit of polish is worth finding out. It would likely be either above the vin or behind the mirror, both of which I don't need to see out if it goes poorly. Which, I figure there is at least a 50% chance of.
edit to add: curious to the effects on gps as well.
Old 03-19-2010, 02:51 PM
Freeman's Avatar
Unregistered User
GPS effects are 0%. be that it's from a standard housed unit or a cell phone. You can "scrub" or "polish" all you want but again, I'm pretty sure it's "inside" the windshield.
Old 03-19-2010, 03:07 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
It does have an effect on the GPS when it comes to first acquiring a signal and driving between larger buildings. The older units have a lot more issues, and the one I tested years ago with a decibel readout on signal strength showed a noticeable loss. It's usually not something I notice,but some parts of manhattan will give me a weak signal warning when it's sitting on the dash.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-19-2010, 04:24 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Im not sure the TiO2 would have any effect on radar signals... which are usually 10-35Ghz...... much longer wavelength than UV. Visible light passes thru the windshield just fine obviously, and radar signals are much further down the spectrum.
Old 03-19-2010, 04:48 PM
Paulrio74's Avatar
I'm getting ahead of myself, but, I've always been one to see physical effects myself when possible. I know a couple of cops through work, so if I go through with this, I will try to get some radar data on the range effects, or if my detector is just a pos. Also gps startup times. It will be completely unscientific or repeatable for others, but why not? I'm an information junkie.
This really stems from my desire to use a valentine 1. My buddy has one I might be able to test with. I can put the unit in the grill and use the remote display, but then I lose backwards/360 detection. I'm unwilling to spend the big bucks to get a detachable front and back sensor model. So I'm back to around the rear view mirror. My current detector (a bell ?, came with the car) worked a little at first, but now make so little noise ever, I stopped paying attention. I just see if it does anything when I go by the radar stands. I try to use my cruise control, except when passing. I would like to know not to pass when it is safe, but patrolled.
Anyway, good discussion so far, thank you all. Keep it going.
edit: it does work when I hold it out the window or sunroof, but that draws a little attention and my arm gets tired.
Old 03-21-2010, 01:19 AM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
You could make a fake dog's head to stick out the window or sunroof with the detector hidden inside...
David C.
