Old 03-02-2010, 08:57 AM
g.l.anthony g.l.anthony is offline
car wont start?????
hi, maybe someone out there can help me with this. bought a 93 svx about a year ago, has always run great!!! last time i drove it , it started fine,ran good as always, well,went to drive it a couple of days later, wont crank!!! spins over great, checked fuses, it is gettin fuel, know nothing about these cars, yet!!!! can anyone tell me what to check????
Old 03-02-2010, 09:22 AM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: car wont start?????
so you hear your starter spinning?
Old 03-02-2010, 10:35 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Wont crank?? Or just doesnt fire up???
Go get some starting fluid and use one of the big vacuum ports on the intake tube to spray it in while you have someone crank. This way you can narrow it down to either fuel or spark, and confirm timing is ok. Also check your ECU for codes just in case one set.
