Old 02-09-2010, 03:27 PM
JreM JreM is offline
4.44 tranny to European SVX
Hello!
I'm halfway through with my tranny swap.. meaning that I've gotten the old one out .. Anyway I found a 4.44 ratio 4EAT tranny from a -94 2.0T Legacy and hope to get it working in my SVX. That's why I thought it would be a good idea to ask if there's anyone here who has done this. The code for my "new tranny" would be TZ102ZB1AA-JR.. Not 100% sure it was that but close. So is there someone who could tell me now if it's going to work or not? Of course I will also change the rear diff's ratio and get the Quick Change Shift Kit - Thanks in advance!!
Old 02-09-2010, 03:54 PM
Re: 4.44 tranny to European SVX
Originally Posted by JreM View Post
Hello!
Hi Jere. As I said on the Forums, it depends if the Legacy box is a VTD and has the front speed sensor inside the box, or driven off the front differential, above the right front axle. The TCU in your car will only work with a VTD box with internal speed sensors.
If the box is not a VTD and has the front speed sensor on the front diff,( like the US box) there is a chance that you could use a US TCU, But you would have to change some of the wiring to allow the AWD and speedo to work, but this has not been tried before.
Old 02-09-2010, 03:58 PM
Hello!
Kia ora,
Assuming that as one would expect, your European SVX has VTD with centre differential and the Legacy a centre clutch, the change over would be very complicated. In any event, you would wind up with an inferior car.
If you insist on changing to a clutch type transmission, I can assist you further with information regarding the pitfalls and remedies involved, but I would not advise you to proceed.
Beware. Alex-SVX from Norway was mislead in this regard and has been caused a great deal of strife.
Old 02-09-2010, 04:28 PM
oh.. yeah. Forgot to mention that it is the VTD type.. No external speed sensor.. And thanks Harvey, I wouldn't have found this one with out your advice in the Forums The tranny that I'm planing to put in is from Japan. It's from a -94 2.0 turbo legacy with under 60000 miles on it... And I was actually only interested to see if anyone else here had done this to the VTD tranny car.
Old 02-09-2010, 05:00 PM
That sounds like you have found the right one. That should be a straight swap.
No I think you are the first to do it.
Old 02-10-2010, 06:38 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Please double check that BOTH legacy and SVX boxes are VTD and have internal speed sensor #2 (not in the front diff).
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
