Old 02-09-2010, 06:52 AM
Pierre-Olivier's Avatar
Pierre-Olivier Pierre-Olivier is offline
AWD or VTD ?
Hello everyone,
My SVX 3.3i A '94 is from Belgium, is it a AWD or VTD ? What the best ?
Thanks.
Pierre-Olivier
Old 02-09-2010, 07:13 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: AWD or VTD ?
http://www.subaru-svx.net/forum/show...67l#post485067
Your transmission is VTD. VTD is better than ACT4.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 02-09-2010, 07:23 AM
Re: AWD or VTD ?
Thank you, my car is a 4 wheel drive ?
Old 02-09-2010, 09:42 AM
NeedForSpeed NeedForSpeed is offline
Re: AWD or VTD ?
Yes, Phil is correct, your car is All Wheel Drive VTD, confirmed by the (Diff Lock) fuse. This is why I asked to see a picture of your fuse cover.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 02-09-2010, 10:10 AM
Re: AWD or VTD ?
O.K, thank you very much !
Old 02-09-2010, 10:41 AM
Re: AWD or VTD ?
"All versions of the SVX sold were equipped with automatic transmissions. Depending on the country, Subaru had two versions of their All-Wheel-Drive system for the automatic transmission, called ACT-4 or VTD. The first system, called ACT-4 (Active Torque Split) by Subaru, was the same setup commonly found on other Subaru models of the period, and used a variable clutch pack center differential using a 90% / 10% power split front to rear, which could transfer up to a 50% / 50% power split for maximum traction if the front wheels started to slip, allowing better fuel economy. This AWD system was offered throughout the entire production run, and was used in vehicles manufactured for sale in the USA, Canada, Germany, France and Switzerland. A sportier continuous traction delivery system, called VTD (Variable Torque Distribution) by Subaru, was used in vehicles for sale in Japan, England, the Benelux region of Northern Europe, Australia, Spain, Austria and Brazil. The VTD AWD system is a permanent AWD due to its 36% / 64% split.[4] The Japanese-spec SVX was equipped with four-wheel steering (4WS).
Subaru began to realize that the high selling price of the SVX was giving some buyers "sticker shock". In an attempt to attract more buyers, a Front Wheel Drive FWD version was offered on the SVX during the 1994-1995 model year, which cost about $1500.00 less than the AWD version. In 1994, FWD was offered on both the L model (X33 in the VIN) and on the LS model (X34 in the VIN). In 1995, only the L model was offered in FWD (X33 in the 5th, 6th and 7th digits of the VIN). Buyers avoided the compromised FWD version and weak sales figures led to its discontinuation after 1995
source : wikipedia.
