View Poll Results: How long has your transmission lasted?
0-25,000 miles 3 10.00%
25,000-50,000 5 16.67%
50,000-75,000 6 20.00%
75,000-100,000 8 26.67%
100,000-125,000 5 16.67%
125,000-150,000 4 13.33%
150,000-175,000 3 10.00%
175,000-200,000 2 6.67%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Old 02-10-2010, 07:16 PM
rlutz rlutz is offline
Re: How long has your transmission lasted?
Originally Posted by Bohler View Post
I am on number 3. First replaced at 90,000 miles by previous owner, 2nd replaced by me after front diff failed at 175,000 miles and currently at 204,000 miles with no problems.
Sounds like you've got it right. What were the symptoms of a failed front differential? What's your secret for maintaining a 200K+ transmission?
Old 02-10-2010, 07:28 PM
Bohler's Avatar
Bohler Bohler is offline
No that is how many miles is on the car first one lasted 90,000 miles, second one lasted 85,000 miles and I am still using the third one.
When the diff went it made a loud clunking noise which increased with the speed of the car. Pulled over right away and had it towed home. I was hoping it was a bad axle. When I put it on the lift with it in park I spun one front wheel which would normally cause the opposite wheel to spin backwards, which it didn't do so I knew something in the diff was gone. Never took it apart but I am pretty sure it sheared off some of the gears. My AWD didn't work before that so I just changed out the entire transmission.
Old 02-10-2010, 07:35 PM
Got it. Do you think driving with an inoperative AWD caused the front diff to fail? How long were you without AWD? (that's my current problem)
Old 02-10-2010, 07:51 PM
Bohler's Avatar
I don't think it had anything to do with it. Not really sure how long I was without AWD. I was told by the person I bought it off of that it worked, but not really sure if it did. It had 160000 miles on it when I bought it in Sep07. I changed the transmission fluid about 5000 miles after I got it and found large pieces of metal stuck to the magnet, but my transmission shifted fine. Took it all out and changed both the internal and external filter and made sure I had enough money in my bank account for another trans because I was unsure where the metal came from and how long the trans would last. I found out the AWD didn't work during the first snow we had about 4 months later. Transmission lasted until July08 when I was at a light making a right turn. Applied more throttle than necessary when pulling out and hit a pothole midturn and it started clunking immediately; that is why I thought it was a bad axle. So it was driven at least 10000 miles without AWD.
Old 02-10-2010, 07:57 PM
MadMaxSvx's Avatar
MadMaxSvx MadMaxSvx is offline
When the AWD is not working the front diff have more work than normal, the rear diff is always "pushing" the car, so it releases some of the stress from the front end... think about it.
95´ Subaru SVX EURO
85' Mercedes 190 2.3-16
86' Mercedes 190E
70' Olds Toronado
98' Renault Chamade
82' Honda Prelude
79' Honda Accord awaiting restomod.
69' Mustang Hardtop
67' Jeep Ford Willys awaiting restoration.
67' IKA Torino Coupe
74' Renault Torino Coupe
Old 02-10-2010, 08:12 PM
Yeah, but the normal distribution is 90% FWD and 10% RWD. I wouldn't expect that extra 10% to be that significant, especially when I'm not using that much power regularly (I'm at 6800' elevation where the engine might make 180hp tops and I don't accelerate hard that often anyway...).
Old 02-11-2010, 02:59 AM
kwren's Avatar
kwren kwren is offline
OMG, do you fill your transmission with the proper liquid?
I don't fill it at all... the dealers do. I also have a transmission cooler installed and the subaru external filter kit
Keith
Old 02-11-2010, 11:09 AM
That's not true... It hardly ever only puts 10% to the rear wheels. On just normal acceleration from a stop it is usually between 70/30 and 60/40 split so driving without AWD puts a lot of extra stress on the front diff. About the only times that the AWD is in 90/10 is if you are coasting or braking.
Old 02-11-2010, 11:23 AM
Thanks! I hadn't really realized that...
