Old 02-08-2010, 12:47 PM
Re: My '92 Transmission just went (no 4th gear, 1-3 slip)... Japanese Tranny question
Originally Posted by customesp View Post
Might of found a tranny from a 96 svx for $300... will it be a direct fit? will I also need the rear dif? Should I do it?
won't need the rear diff, the tran will be a direct replacement. And a 96 trans has all of the updated done to it so it should be more reliable. Just make sure the brake band is adjusted correctly before install. I can't recall the process off the top of my head so just search "brake band adjustment" or i'm sure someone will pipe in...
Old 02-08-2010, 05:13 PM
You asleep at the keyboard Nate??
Check LINK in post #7
