Old 01-22-2010, 01:29 PM
rlutz rlutz is offline
Fast idle doesn't reset automatically
A minor annoyance, but my SVX fast idle does not reset itself after the car warms up (stays up near 1700-2000rpm). I can drive 30 miles on the freeway in the morning, come off and the idle will run at 2000rpm (in neutral). It will reset itself, if I briefly turn-off the engine and re-start (drops back under 1000rpm and stays that way for the rest of my commute).
Any ideas?
The car is garaged, so starting temps are not really cold, only around 45-50F. Outside temps are colder 5-35F...
92 LS-L
169,000 miles
Old 01-22-2010, 01:33 PM
Re: Fast idle doesn't reset automatically
mine does this after it was converted to a 5MT.
Old 01-22-2010, 01:36 PM
processengr's Avatar
Any ideas?
92 LS-L
169,000 miles
I had this exact problem with both of our '92s. If you shut the car off and restarted the idle would return to normal. Shifting from 1st to second was a bit delayed and down shifting was a little off also. In both cases, replacing the TPS fixed the problem.
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 01-22-2010, 02:23 PM
Thanks! Worth a try...
Ouch! $213 at 1stsubaruparts.com, now why did I think it might only be a $60-$70 part!
Old 01-22-2010, 02:49 PM
dcarrb dcarrb is offline
You can get the identical part from Autozone (or is it Advance?) for something in the neighborhood or $175. At least that was their price a couple of years ago...
dcb
Old 01-22-2010, 06:44 PM
It is very possible that the TPS simply requires adjustment, rather than replacing. The associated throttle stop adjustment can also be affected, if things here are haywire.
Refer the how too stuff for instructions.
Old 01-22-2010, 07:14 PM
tps being out of range would cause many more problems ,like erratic shifts and a bad idle ,these cars use a aux air valve for fast idle if it is stuck open it will run the engine fast ,the valve is mounted on the manifold between #4 and 6 cylinders pinch the line off going to the throttle body and see if the idle drops
charlie
Old 01-22-2010, 07:31 PM
charlie
A TPS slightly out, in respect of being fully returned to zero, or preventing the throttle to completely close, will not cause the multiple problems mentioned and can not be ruled out as is suggested.
However, it is granted that the fault could be the result of several issues.
