Old 01-17-2010, 08:28 PM
jjanak79's Avatar
jjanak79 jjanak79 is offline
protectors
I have had my spoiler off for about 3 months now and i cant find the rubber protectors for it. does anyone have any or is there any ideas for a replacement. i really need to get this spoiler back on.
94 Subaru SVX FWD 51k
04 Mazda B4000 (work truck)
Old 01-17-2010, 08:45 PM
Re: protectors
Order them from your dealer.
2...96054PA020...Protector R/spoiler,...about $13.00 each (part #3)
4...96054PA030...Protector B,...about $2.50 each (part #4)
Old 01-18-2010, 12:03 AM
kwren's Avatar
kwren kwren is offline
Re: protectors
Thanks! I needed that...
Keith
Old 01-25-2010, 03:17 PM
jjanak79's Avatar
Re: protectors
ok. i went to the dealer and they gave me some wierd gaskets. not the ones that came of the spoiler. it was just a strand of gasket. not the whole thing. idk what to do now.
Old 01-25-2010, 03:22 PM
Cam Cam is offline
Re: protectors
judging from the picture it looks like it may just be a gasket similar to our valve covers (just goes around the periphery of the mating surface between spoiler and trunk lid. When you install it you can hold it in place with a little silicone to keep the gasket from wandering.
Old 01-25-2010, 05:43 PM
Re: protectors
The strand of gasket material IS correct. You just make an onal out od it to match the bottom of the spoiler mounting face and press the ends together to form a seal
It is not a preformed shape. The material is used as a cushion between the trunk and spoiler and to see out moisture.
Old 01-25-2010, 06:29 PM
Elliott's Avatar
Elliott Elliott is offline
Re: protectors
You could probably just get some simple foam weatherstripping from Home Depot that will work just as well and probably cost a lot less.
My method was a little more costly but worth it:
Old 01-25-2010, 07:37 PM
Re: protectors
You can get this material from your auto parts supplier. It is called 3, Strip-Calk (No. 08578) Comes i a box of 60 one-foot strips. Thetre are a lot of uses for this stuff.
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
Old 01-25-2010, 08:57 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: protectors
nice job there. did you have the spoiler set back farther?
Old 01-25-2010, 10:25 PM
Elliott's Avatar
Re: protectors
Yeah, I moved it back about 3-4", I hate where Subaru put them, just looks wrong to me.
Old 01-26-2010, 12:20 AM
Re: protectors
I love what you did there, looks great. I think I'll do the same when I get the black top painted.
Old 01-26-2010, 01:15 AM
Elliott's Avatar
Re: protectors
This kinda shows how far it went back, this was how I mocked it up to get the positioning exactly where I wanted it.
If you want to copy this, make sure you get someone who knows fiberglass really well to do it, it can be tricky to get it right and not have issues down the road. It will also be tricky to paint since it is now one piece. Also, make sure the wing can breathe, if it is totally sealed, it will crack when the air inside heats up, it has breathing holes from the factory, but they will most likely get covered up.
I am not sure how much a shop in your area would charge to do this properly, might not be cheap, I have a lot of hours in grinding and shaping it to make it perfect and flow exactly how I wanted it to. I have a lot of time in little modifications in an effort to make the car more smooth, shaved the door handles, the windshield washer squirters on the hood, the hood emblem, the trunk lock and the antenna. More or less just to show off what I can do, since I work in a custom and collision body shop, sadly I had to show off some of my collision skills too when I replaced the passenger's quarter panel.
Old 01-26-2010, 03:12 AM
BRugNY BRugNY is offline
Re: protectors
Great looking spoiler, I think you really out did Subaru with that one!
Old 01-26-2010, 11:38 PM
Re: protectors
Very cool, looks very well done. Is Kannapolis anywhere near raleigh/durham? I might be road tripping there to visit family this spring break.
Old 01-27-2010, 12:12 AM
Elliott's Avatar
Re: protectors
Raleigh is about a 3 hour drive from me, I am close to Charlotte.
